Autopsy part 1.., Nasty bits |
Porschef |
Jul 25 2011, 10:52 AM
How you doin' Group: Members Posts: 2,180 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
So I had a chance to drain the oil yesterday and it looked good till I got to the bottom of the drain pan where I found a couple of small shards of non metallic material that looks suspiciously like bearing bits. Not a lot, but enough to use as evidence. The engine really did not run very long after hearing that sweet banging noise. I did start it for a very brief time twice after that, (no more , Andy) and it would fire right up.
So my question is, what might be the results of a spun bearing? If the bearing is toast, what would create that sound? Is head damage a possibility or likely? I can't get to removing the engine for a while, just hoping to know what to expect, maybe. Thanks, Joe |
cwpeden |
Jul 25 2011, 06:49 PM
Great White North, huh? Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
Nonferrous for sure? Sounds like mine when it detonated a cam follower. When you take off the valve covers and check valve clearance it will be clear. When mine let go it took the cam with it.
Good luck, Conrad |
Lo-Fi Version | Time is now: 22nd December 2024 - 12:28 PM |
