> 74 Distributor Vacuum Question, How many ports?
74914LE
post Jul 24 2011, 11:44 AM
In sorting out the hoses on a 74 2.0, I discovered that the vacuum advance has
two ports coming out of it (Top Side/Bottom Side), however my intake only has
one vacuum port. It is currently hooked up with the line going to the top side
port on the distributor, and the bottom side is open. Question is, should this be
plugged, or does it need to be connected to vacuum, and if so where to hook it
up? Based on the information I was able to find, it looks like I have a early 2.0
distributor, and a later 2.0 intake. Any issue here?
Thanks!
74914LE
post Jul 25 2011, 07:00 PM
Thank you for the great feedback. There are so many variables with certain areas on our cars. To confirm, the advance port (points to drivers side), does
not get connected, and the retard(points to passager side) gets connected. Also,
the size of the port on the intake, and the port on the distributor should be of the
same size when connected?
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 26th December 2024 - 10:54 PM
