> Autopsy part 1.., Nasty bits
Porschef
post Jul 25 2011, 10:52 AM
How you doin'
So I had a chance to drain the oil yesterday and it looked good till I got to the bottom of the drain pan where I found a couple of small shards of non metallic material that looks suspiciously like bearing bits. Not a lot, but enough to use as evidence. The engine really did not run very long after hearing that sweet banging noise. I did start it for a very brief time twice after that, (no more , Andy) and it would fire right up.
So my question is, what might be the results of a spun bearing? If the bearing is toast, what would create that sound?
Is head damage a possibility or likely?
I can't get to removing the engine for a while, just hoping to know what to expect, maybe.
Thanks,
Joe
cwpeden
post Jul 25 2011, 06:49 PM
Great White North, huh?
Nonferrous for sure? Sounds like mine when it detonated a cam follower. When you take off the valve covers and check valve clearance it will be clear. When mine let go it took the cam with it.
Good luck,
Conrad
Porschef
post Jul 25 2011, 08:26 PM
How you doin'
QUOTE(cwpeden @ Jul 25 2011, 08:49 PM) *
Good luck,
Conrad
Ooof. (IMG:style_emoticons/default/barf.gif)
Well, I gotta do more research and study. As much as I want mas cajones out of the type IV, a 2056 w/ stock djet seems to make the most sense for me.
Joe
- Lo-Fi Version Time is now: 22nd December 2024 - 12:08 PM
