Dead Temp Gauge. |
Dead Temp Gauge. |
steuspeed |
Jul 27 2011, 07:41 PM
Senior Member Group: Members Posts: 1,008 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
So I'm fixin the little things on my new 914. The temp gauge is dead. I poked around on the net and did some searches on 914 World. I can't seem to find the info I'm looking for.
Located the taco plate and the wire running up into the engine compartment. There is a connector there so I hooked up a volt meter to the wire to see if the sender would give me a voltage reading that moved after I started the car. I got 0-.1 Volts after several minutes. Is my sender dead? Should I be seeing a voltage range or am I way off base with my test? Stewart |
Lo-Fi Version | Time is now: 27th December 2024 - 08:24 AM |
