Series9 |
Lesbians taste like chicken. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States ![]() |
It occurs to me that we've been throwing around some pretty big numbers in my 3.2 exploits of late.
I want to see how little I can spend converting Luckie's 914, but still do the job correctly. Here are the parameters: The engine has to be no larger than 2.4. This will save us the major expense of having to provide external cooling. The oil system will only be tank and lines. The 2.4 will use an early 901 911 flywheel, which I should be able to find used. It will also use a stock clutch. The goal on this one will be finished for $5k. I sourced a core 2.2T engine for $300. Since it was so little, I have quite a bit of room to fix whatever it needs, but 911 parts get expensive fast. I'm going with Megasquirt II fuel injection possibly on a custom-built intake manifold. This arrangement will not use the expensive 914/6 bellcrank conversion, but rather a simple 914/4 stock throttle cable. Current expenditures listed below: Engine mount: $90 2.2T engine (long block, delivered): $195 (cost adjusted for unneeded parts sold off) Megasquirt II ECU: $85 FI components (relay board cables and wiring): $219.25 Intake: $55 Headers: $168 Crank-fire pulley kit: $175 Blast headers: $10 POR-20 for the headers: $37.02 Current total $1034.27 (IMG:style_emoticons/default/sunglasses.gif) |
Woody |
Sandbox Rabblerouser and head toilet scrubber ![]() ![]() ![]() ![]() Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region ![]() |
Are there any disadvantages to using a front tank setup like this? The reason I ask is this may be the route I choose so I can get a little bit better weight distribution.
http://www.patrickmotorsports.com/part/401/ |
Series9 |
Are there any disadvantages to using a front tank setup like this? The reason I ask is this may be the route I choose so I can get a little bit better weight distribution. http://www.patrickmotorsports.com/part/401/ This arrangement lurks under the front deck on my car: Attached image(s) ![]() |
Woody |
Are there any disadvantages to using a front tank setup like this? The reason I ask is this may be the route I choose so I can get a little bit better weight distribution. http://www.patrickmotorsports.com/part/401/ This arrangement lurks under the front deck on my car: Yeah that's very similar to what I had in mind especially since ill be running a cooler. Didnt mean to thread Jack but that tank is substantially less than a fender mount. |
Lo-Fi Version | Time is now: 25th June 2024 - 08:03 PM |
