For My Next Trick, Minimum Cost /6 Converion, An experiment to show low cost done well. |
Series9 |
Jul 29 2011, 09:27 AM
Lesbians taste like chicken. Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
It occurs to me that we've been throwing around some pretty big numbers in my 3.2 exploits of late.
I want to see how little I can spend converting Luckie's 914, but still do the job correctly. Here are the parameters: The engine has to be no larger than 2.4. This will save us the major expense of having to provide external cooling. The oil system will only be tank and lines. The 2.4 will use an early 901 911 flywheel, which I should be able to find used. It will also use a stock clutch. The goal on this one will be finished for $5k. I sourced a core 2.2T engine for $300. Since it was so little, I have quite a bit of room to fix whatever it needs, but 911 parts get expensive fast. I'm going with Megasquirt II fuel injection possibly on a custom-built intake manifold. This arrangement will not use the expensive 914/6 bellcrank conversion, but rather a simple 914/4 stock throttle cable. Current expenditures listed below: Engine mount: $90 2.2T engine (long block, delivered): $195 (cost adjusted for unneeded parts sold off) Megasquirt II ECU: $85 FI components (relay board cables and wiring): $219.25 Intake: $55 Headers: $168 Crank-fire pulley kit: $175 Blast headers: $10 POR-20 for the headers: $37.02 Current total $1034.27 (IMG:style_emoticons/default/sunglasses.gif) |
Root_Werks |
Aug 1 2011, 11:14 AM
Village Idiot Group: Members Posts: 8,341 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Not really sure if there is a true low budget 914-6 conversion possible anymore unless you have good connections. The average person will spend way more to convert one than you could buy one for. It USE to be totally worth it for the average bear:
Factory oil tank = $450 Used heater boxes = $500 Bursch headers (save a buck and time to hunt down heat) = $200 Used small 2.0-2.4 non "S" engine = $1000-1500 complete with muffler Flywheel = $100 911 "Soft long" oil line = $65 Egnine tin = Free (I use to have templates) Shifter bar = Free (I use to have a jig) Muffler hanger = Free (I use to have a template) Bell Crank = $15 for solex balls and cups, (I use to have jigs and templates) Sell your 4cyl 1.7-1.8 $0, 2.0 $500 This was 10+ years ago, shoot, probably more like 15+ years ago. I've seen some pretty good conversions go for $10-15k that looked to be clean cars. Not really sure if you could source all that, put it together for the same price anymore. |
Lo-Fi Version | Time is now: 25th June 2024 - 07:58 PM |
