RiqueMar |
Enrique Allen Mar ![]() ![]() ![]() ![]() Group: Members Posts: 2,220 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California ![]() ![]() |
I'm in desperate need of help with this CDI wiring on my conversion. The wiring I pulled off the 77' is just in horrible condition, as you will see in the pictures below, and I wouldn't be surprised if the wires are colored wrong or spliced wrong.
I'm not sure where each of the leads go, and I can't seem to find anything on an assortment of diagrams. (IMG:http://www.914world.com/bbs2/uploads_offsite/i16.photobucket.com-9478-1313108475.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i16.photobucket.com-9478-1313108475.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i16.photobucket.com-9478-1313108476.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i16.photobucket.com-9478-1313108476.4.jpg) |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Four wire to a 3 pin CDI box. Look at the end of the box ... terminals are labeled "A", "B" & "C"
"A" = to Terminal 15 on transformer (not an effin' coil). "B" = Switched power B+ "C" = Tach input & trigger wire from points Last wire CDI case to ground (spade terminal) |
RiqueMar |
Four wire to a 3 pin CDI box. Look at the end of the box ... terminals are labeled "A", "B" & "C" "A" = to Terminal 15 on transformer (not an effin' coil). "B" = Switched power B+ "C" = Tach input & trigger wire from points Last wire CDI case to ground (spade terminal) Is this the part where you slap me in the back of the head and say, 'Don't make me have to tell you again, kid" Thanks Ron! |
Lo-Fi Version | Time is now: 20th April 2025 - 06:45 AM |
