deloreandude86 |
Austin Burkhardt ![]() ![]() Group: Members Posts: 61 Joined: 18-August 10 From: Austonio, TX Member No.: 12,068 Region Association: South East States ![]() |
Hey all, I'm having some issues with my engine. its a 1.7L Dual Carbed. Everything electrical is brand new, Plugs, wires, distributor, (including points), coil. I believe its getting proper gas flow but it's weird though because it idles fine. If reved and the instantly released it sounds great kicks right up no problem, however if brought up to about 3500-4000 or greater and held, it makes a poping noise and looses rpms. also on take off, give it a couple revs, sounds great, put it in first and take off, it'll throw you back in the seat then it hits about 3000 rpm and starts bogging down, shift to second and its about the same deal. In 3rd it starts to bog down and tops out about 45mph. 4th is really starting to bog and on the road can hit about 50. 5th gear is a notch above chugging it out completely. pedal clear to the floor and its loosing speed, any ideas guys?
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
I had a similar problem. I ended up being the fuel filter. As fuel velosity increased a large burr from machining would clog the output barb. The engine would die when it reached 3500rpm.
If your compression is that low, you have other issues... (IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 09:02 AM |
