Tom |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None ![]() |
I have a little rust and a crack on the bottom of the passenger side jack point.
Rest of longs, and hell hole is great. Should I just have the bad spot cut out and reweld in new metal, or replace the whole jack point piece. If replacing the whole piece is the right way, how do you remove the old one? Cut/grind it out or drill out the spot welds? Thanks, Tom Attached image(s) ![]() ![]() ![]() ![]() ![]() ![]() |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
If that was me, I would cut off the bottom of the jack post.
For you, take a much closer look inside the jack post via the "drain hole" that IC is clogged with rust. Clean that out with a pick and vacuum....then decide. The problem is that the jack post is full, and has been full, of junk for many years...so the wall behind it is what most likely is rotted. RIch |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
If that was me, I would cut off the bottom of the jack post. For you, take a much closer look inside the jack post via the "drain hole" that IC is clogged with rust. Clean that out with a pick and vacuum....then decide. The problem is that the jack post is full, and has been full, of junk for many years...so the wall behind it is what most likely is rotted. (IMG:style_emoticons/default/agree.gif) And that crack looks like it's rusted through. Clean that up and poke (hard) with a flat screw driver. If you can poke through around the crack, it's time for some cutting ... (IMG:style_emoticons/default/sawzall-smiley.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 07:17 AM |
