Dummy of the Month, ruined my relay board! |
Ian Stott |
Aug 20 2011, 12:36 PM
Senior Member Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
Should have talked to my mechanic, but noooo I figured I'll just unplug the things plugged into the relay board, clean everything all up and reinstall it, well lots of smoke, evacuate the house, move cars out of the driveway to get the teener outside so I don't lose the house as well! Could see flames and of course the wife is now hysterical saying helpful things at the top of her lungs like "do something" get the battery unhooked and blow out the flames which were melted burning pieces of the relay board. Car is okay, smoke has cleared, only the relay board is damaged and now I can't get the last plug unplugged as it seems to be melted into the board, help me please! Anyway my momma said there would be days like this. Thought I would share my experience with everyone, I think it takes me out of the loop of guys you ask for help! Maybe we should have a dummy of the month same as car of the month, not trying to get the misery loves company bandwagon afloat but please tell me I'm not the only one who has fuched up!
Ian Stott Moncton Canada |
Tom |
Aug 20 2011, 12:59 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Sorry to hear this. Hopefully the wiring harness is OK.
Whenever working on the electrical things on the car, always remove the battery cable on the negative side of the battery. When you are done working/fixing, hook it back up - paying attention to any arc when doing so. Don't tighten the bolt. If after starting and running the car all is well then tighten the bolt. This makes it easy to yank that cable back off to stop an electrical fire. If it arcs, it means you have a large load that you did not have before. Find out what the load is, then rehook it up. So, do you know what you did to cause this? Wires plugged in off set or something on the board shorted? Tom |
Ian Stott |
Aug 20 2011, 01:07 PM
Sorry to hear this. Hopefully the wiring harness is OK. Whenever working on the electrical things on the car, always remove the battery cable on the negative side of the battery. When you are done working/fixing, hook it back up - paying attention to any arc when doing so. Don't tighten the bolt. If after starting and running the car all is well then tighten the bolt. This makes it easy to yank that cable back off to stop an electrical fire. If it arcs, it means you have a large load that you did not have before. Find out what the load is, then rehook it up. So, do you know what you did to cause this? Wires plugged in off set or something on the board shorted? Tom I unplugged everything with no issues until the plug closest to the firewall, I just moved it a little and it started smoking, and then I saw flames, I ran in the house and told everyone to get out, the teener is on fire then went back into the garage from outside and unhooked the neg. side of the battery and then blew out the flames which were coming from melted pieces of plastic which was from the underside of the relay board. |
Lo-Fi Version | Time is now: 5th February 2025 - 12:51 AM |
