tadink |
Member ![]() ![]() Group: Members Posts: 379 Joined: 28-December 09 From: Napa Member No.: 11,181 Region Association: Northern California ![]() |
Hey all - Please allow me to introduce myself and I'll post some pix as soon as I can. I'm a longtime PCA member and have restored a 67 911 that is still in the family....now I've gone an purchased a 73 914 1.7L Fuel Injected car in the Bay Area. It has been sitting for a bit, does not have appreciable rust, and seems in generally good shape apart from some mostly minor issues.
Question - after having been sitting for 6+ months, she fired up and ran - but a bit rough. No engine noise or knocks, but the idle is rough, it stalls at low rpms, and is pretty rough except under a good amount of throttle. I'm thinking dirty injectors at least - what is the best course of action from here? options - add injector cleaner, good gas, run the bee-jesus out of her option2 - get the thing to the mechanic and let him sort it out option3 - ???? your help and guidance is appreciated - I've had great success with the lads on the Pelican Parts 911 board, and you all seem quite helpful as well as I've read thru the posts on this board. Hope to be able to contribute as well as learn... best tom |
tadink |
LOL - - you guys are the best, and I'd take your advice if I knew what the heck you were talking about - - - MPS, TPS, huh?
I need an idiot's guide to fuel injection, clearly! Is there such a resource anywhere on the site? something that takes total newbies like me thru the basics of what the heck I'm dealing with? Pix in the morning - got the driver's window replaced (broken out by hoodlums) and put on the inner door skins, inside door handles, and started taking some inventory of what this 'near barn find' has to offer. The vandals took most of the screws out of anything that had a screw in it - - - what is the value of a screw???? - - - - and so there is a bunch of stuff rattling around loose! They also cut out the headlamp motors, so I have that to deal with yet. AND they took all the fuses! really, the fuses???? good grief....LOL but, all in all, minimal rust that I could find. Tomorrow I dig into the engine bay - and I'll look around for an MPS or a TPS - thanks for all your help - - - td |
swl |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada ![]() |
I need an idiot's guide to fuel injection, clearly! Is there such a resource anywhere on the site? something that takes total newbies like me thru the basics of what the heck I'm dealing with? That would be Brad's site. It looks a bit overwhelming but if you take an hour and go through it at you'll have a good grasp of the parts involved and understand the secret language (IMG:style_emoticons/default/smile.gif) http://members.rennlist.com/pbanders/djetparts.htm The MPS is the manifold pressure sensor. often described as looking like a hand grenade. to the rear of the battery mounted to the inner fender well. It controls the enrichment process when you open up the throttle. The correct answer to the question of holding a vacuum is to buy or rent a vacuum puller (small pump with a guage on it). Bring the vacuum up to the specided test value (see Brad's site). And watch to see if it holds that vacuum. The quick and dirty first check is to just suck on the port and use your tongue to seal off the port. You will look real silly but if the diaphram is leaking badly you should know right away. If it seems to hold you should probably do it again with the vacuum puller to ensure there aren't slow leaks. |
tadink |
I need an idiot's guide to fuel injection, clearly! Is there such a resource anywhere on the site? something that takes total newbies like me thru the basics of what the heck I'm dealing with? That would be Brad's site. It looks a bit overwhelming but if you take an hour and go through it at you'll have a good grasp of the parts involved and understand the secret language (IMG:style_emoticons/default/smile.gif) http://members.rennlist.com/pbanders/djetparts.htm The MPS is the manifold pressure sensor. often described as looking like a hand grenade. to the rear of the battery mounted to the inner fender well. It controls the enrichment process when you open up the throttle. The correct answer to the question of holding a vacuum is to buy or rent a vacuum puller (small pump with a guage on it). Bring the vacuum up to the specided test value (see Brad's site). And watch to see if it holds that vacuum. The quick and dirty first check is to just suck on the port and use your tongue to seal off the port. You will look real silly but if the diaphram is leaking badly you should know right away. If it seems to hold you should probably do it again with the vacuum puller to ensure there aren't slow leaks. Thanks for the link - I spent a couple of hours there and chasing all the links from that site so I think I know that I don't know very much now, but might have a chance at spotting possible errors.... Re: your suggestion about checking the vacuum - FANTASTIC - that's the sort of help I need. Take off a really dirty hose and suck on it, holding the vacuum with your tongue! LOL That should pretty much convince my wife that I have indeed lost my mind - if the purchase of this thing did not already! I'll take you at face value (and assume you are not just initiating a newbie to the board with a silly task!) and go see if I can find the MPS thing and see what might be attached to it - - - I did manage to find two hoses with bolts stuck in them. I'm thinking this might not be 'factory original' since the bolts are oversized and rusty. Doing the diagnosis now to see what custom feature this might be - and to ID the hoses. seriously, thanks for your help on this! td |
Lo-Fi Version | Time is now: 20th June 2024 - 05:47 AM |
