> Fuse block for red wires from batt, EDIT: 3/06/13. not making kits anymore.
Tom
post Aug 22 2011, 06:54 AM
EDIT: 3/06/13
I won't be providing these kits any longer. I apologize to the members who have been waiting. Please feel free to use any info in the thread to help you come up with a fuse solution that meets your individual needs. Parts list on last page.
Tom
NEW INFO FOR EARLY CARS. THEY CAME WITH ONLY THREE RED WIRES!! Two 4.0mm and a much larger wire running forward to the dash area. Please check before ordering.
Last round this summer. Maybe next winter I will do this again if there is a demand.
See pics of the new 4-way and 6-way kits, and the completed install of mine. Kits are designed to go on the outer edge of the battery box, however some have mounted elsewhere. If you have need for longer wires so you can mount yours differently, let me know and we can make that work for you.
Also, please see the two pages of info below. You should be able to print copies.
From the supplier: 4/6 individually fused circuits with connections that enter and exit from the bottom allow this fuse block to be mounted in narrow locations. Clear plastic dust cover is included. Max load capacity for all circuits combined is 50 amps, 65 amps for the 6-way. Connections are made using 1/4" female push-on connectors.
I will open round four as I already have 3 folks who want one. There will be two models, a 4-way and a 6-way, and three stages; 1-basic, 2-connections on and soldered, 3 - with new battery connector.
4-way
stage 1- basic kit $25.00
stage 2- connectors on and soldered and harness heat shrinked $30.00
stage 3- With new battery connector $32.00
6-way
stage 1- basic kit $30.00
stage 2- connectors on and soldered and harness heat shrinked $35.00
stage 3- With new battery connector add $37.00
I will leave this open until 5 June, them order parts. It looks from the last round that you can expect about a month to receive the kit. IE: if I order parts by 6 June, the kits will ship no later than 30 June.
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
Tom
post Aug 22 2011, 09:50 AM
Cap'n,
A member in Canada just had a fire last week. Fire originated at the 14 pin connector at the relay board. Probably damaged the wiring harness before he could get the batt disconnected. Wiring harness is pretty expensive and a fused red wire would have prevented that.
Fuses shouldn't have to be too big. Max capacity of stock alternator is 55 amps. I think each red wire fused at 25 amps would be sufficient. Do you think that would not be enough? Just trying to get the info needed to make a decision.
Thanks,
Tom
Tom   Fuse block for red wires from batt   Aug 22 2011, 06:54 AM
tradisrad   I think putting the fuses in place for the always ...   Aug 22 2011, 07:42 AM
Cap'n Krusty   Why? I have never heard of an instance where thos...   Aug 22 2011, 07:44 AM
Tom   Cap'n, A member in Canada just had a fire...   Aug 22 2011, 09:50 AM
Cap'n Krusty   Cap'n, A member in Canada just had a fir...   Aug 23 2011, 06:43 PM
swl   It would be interesting to know how and why a fir...   Aug 23 2011, 07:04 PM
SirAndy   It would be interesting to know how and why a fire...   Aug 23 2011, 10:12 PM
Ian Stott   Cap'n, A member in Canada just had a fi...   Sep 25 2011, 11:41 AM
76-914   Besides the "cheap insurance" issue, I t...   Aug 22 2011, 10:17 AM
andys   I'm not going to contest the 914 electrical sy...   Aug 22 2011, 11:26 AM
shoguneagle   I have just completed complete wiring of my Sixer ...   Aug 22 2011, 01:20 PM
r_towle   seems like there are two people in this thread tha...   Aug 22 2011, 03:32 PM
Scarlet75   I am interested.   Aug 22 2011, 04:00 PM
Razorbobsr   Looking at doing this for my car. Is any one else...   Aug 22 2011, 04:31 PM
wingnut86   I'll be in as well...   Aug 22 2011, 07:37 PM
Tom   I'll order some parts and when they get in, I...   Aug 23 2011, 11:26 AM
JmuRiz   I'd be in...I've got too many red wires ru...   Aug 23 2011, 11:41 AM
swl   Good initiative Tom. The border is too much of a ...   Aug 23 2011, 05:39 PM
Scarlet75   Good initiative Tom. The border is too much of a...   Aug 23 2011, 06:26 PM
swl   Good initiative Tom. The border is too much of ...   Aug 23 2011, 06:44 PM
Cap'n Krusty   I'm thinking about this a little more. Basica...   Aug 23 2011, 07:58 PM
swl   That fuse also protects the heater fan and the AAR...   Aug 23 2011, 08:20 PM
Tom   Steve, Don't think I could have said it any...   Aug 23 2011, 09:54 PM
montoya 73 2.0   Put me on the list for just one.   Aug 23 2011, 10:33 PM
Tom   I'll be sending out Pm's to those who expr...   Sep 13 2011, 09:55 AM
type47fan   I'll be sending out Pm's to those who exp...   Sep 13 2011, 08:36 PM
moparrob   Count me in. PM sent.   Sep 13 2011, 10:35 PM
Tom   Finally got it finished and tested. :Qarl: Al...   Sep 17 2011, 12:41 PM
Harpo   Good afternoon Tom, I would also be interested in...   Sep 17 2011, 03:38 PM
michael7810   I would like one kit also if it's not too late...   Sep 17 2011, 05:20 PM
JmuRiz   I'm interested too...may as well upgrade the s...   Sep 22 2011, 02:35 PM
Vacca Rabite   Also interested in a kit. I'll be going throug...   Sep 22 2011, 08:02 PM
Gint   I'm interested also. If for no other reason t...   Sep 23 2011, 05:23 AM
Tom   All of the kits have been spoken for. I would have...   Sep 23 2011, 07:22 AM
wingnut86   P.S. Thanks Tom! :first: :trophy: :first:   Sep 23 2011, 09:01 AM
jimkelly   see these http://www.914world.com/bbs2/index.php?...   Sep 23 2011, 10:16 AM
SirAndy   I think I can put it together for under $20.0...   Sep 23 2011, 11:33 AM
Tom   I had no idea there would be such a demand. My fir...   Sep 23 2011, 02:03 PM
Scarlet75   Pretty sure I said I was interested when this firs...   Sep 23 2011, 04:12 PM
Rleog   If you haven't ordered the extra parts yet, pl...   Sep 23 2011, 06:23 PM
bigkensteele   Tom, I just saw this thread. I would also be inte...   Sep 23 2011, 06:53 PM
moparrob   Is your panel basically the same as these pre-wire...   Sep 24 2011, 10:31 PM
Tom   Ian, If your key was in the OFF position, the ...   Sep 25 2011, 01:28 PM
Ian Stott   Ian, If your key was in the OFF position, the...   Sep 25 2011, 01:31 PM
FourBlades   I am interested in getting a kit. I also want to ...   Sep 26 2011, 08:04 AM
stugray   I like the concept & that looks really clean, ...   Sep 26 2011, 01:02 PM
Tom   OK, the parts are on order and the following folks...   Sep 26 2011, 01:15 PM
moparrob   Thanks Tom, PM received. I was hoping you would re...   Sep 26 2011, 01:42 PM
Tom   Moparrob, The fuse block looks the same, but th...   Sep 26 2011, 06:06 PM
moparrob   No problem. Got it. I'll send a check out as ...   Sep 26 2011, 09:14 PM
Tom   At this time all of the kits have been spoken for....   Sep 27 2011, 11:09 AM
Tom   Update on the kits and those who expressed interes...   Oct 2 2011, 02:31 PM
moparrob   Update on the kits and those who expressed intere...   Oct 2 2011, 05:07 PM
Tom   Got the tracking number for the parts and they wil...   Oct 4 2011, 11:44 AM
Gint   I'm a horrible procrastinator with a check. B...   Oct 4 2011, 05:44 PM
Tom   OK Gint, I'll keep on the look-out for it. ...   Oct 4 2011, 07:26 PM
wingnut86   USPS "...Money Gram for Mongo..." :D is...   Oct 5 2011, 01:25 PM
76-914   Wow. Opened my kit tonight. It's very professi...   Oct 15 2011, 10:56 PM
moparrob   Yep, I got mine too. Thanks again - it looks good...   Oct 15 2011, 11:08 PM
Tom   Thanks guys, I have three to ship out Monday t...   Oct 16 2011, 07:23 AM
76-914   Thx, TOM. The fuse block saved me again. I pm...   Feb 7 2012, 01:42 PM
Tom   Kent, That is good news to hear!! :D ...   Feb 7 2012, 02:02 PM
clapeza   Any chance of another run of these coming together...   Feb 7 2012, 02:49 PM
Tom   If there is enough interest, I will consider it. ...   Feb 8 2012, 01:23 PM
Casper   To get the ball rolling, I'll take two. Tom C...   Feb 8 2012, 01:34 PM
burton73   To get the ball rolling, I'll take two. Tom ...   Feb 8 2012, 01:36 PM
1988Hawk   If there is enough interest, I will consider it. ...   Feb 8 2012, 04:58 PM
zymurgist   I will buy one.   Feb 8 2012, 01:42 PM
wingnut86   Tom, I hope this grabs alot of interest, especial...   Feb 8 2012, 02:24 PM
euro911   I'm in for one as well.   Feb 8 2012, 03:43 PM
clapeza   Of course, I'm in for one. Chester   Feb 8 2012, 04:04 PM
somd914   I'm in for one, perhaps another for a friend.   Feb 8 2012, 05:05 PM
Scott S   I will take one as well - :beer2:   Feb 8 2012, 05:09 PM
Black22   I'll take one.   Feb 8 2012, 05:18 PM
bandjoey   +1   Feb 8 2012, 05:19 PM
potomacmidget   I will buy one too.   Feb 8 2012, 09:11 PM
bcheney   +1 for me   Feb 9 2012, 07:39 AM
JRust   I'm in for 2 :)   Feb 9 2012, 09:23 AM
rgolia   I will take one   Feb 9 2012, 10:09 AM
rwilner   Thought people might be interested in some install...   Feb 9 2012, 03:05 PM
Tom   Rich, Thanks for posting the pics. I have been ...   Feb 9 2012, 07:11 PM
rwilner   Rich, Thanks for posting the pics. I have been...   Feb 10 2012, 07:47 AM
jmill   I thought of a aluminum piece with a coating migh...   Feb 9 2012, 07:45 PM
wingnut86   Carbon Fiber :D   Feb 9 2012, 08:20 PM
jmill   Carbon Fiber :D Carbon fiber is pretty but I th...   Feb 9 2012, 10:25 PM
Tom   Well, it certainly looks if there are quite a few ...   Feb 12 2012, 03:53 PM
Black22   I posted earlier, but wanted to say I'm still ...   Feb 12 2012, 05:15 PM
wingnut86   Sometime the local Tractor Supply Company will car...   Feb 12 2012, 06:27 PM
Tom   I found some 1/8" X 1" bar stock that I ...   Feb 15 2012, 01:29 PM
wingnut86   Thanks Tom! Once I land again, I'll doubl...   Feb 15 2012, 02:33 PM
rgolia   I am still in.....I will take the $30 version   Feb 15 2012, 05:34 PM
bcheney   I am still in.....I will take the $30 versio...   Feb 16 2012, 05:17 PM
Tom   I have received replies from all except Zymurgist ...   Feb 16 2012, 07:31 PM
euro911   ... If you have any requests for longer wires for ...   Feb 17 2012, 12:05 AM
Gint   Put me down for a $30 setup.   Feb 16 2012, 10:38 PM
zymurgist   I'll take the $27.50 setup.   Feb 17 2012, 04:56 PM
Tom   Ken, You will have it in a couple of weeks. Only...   Feb 17 2012, 07:09 PM
mzalanka   If it's not too late, I'm in for the ...   Feb 18 2012, 01:59 PM
7275914911   I am also intersted if not to late...PM has been s...   Feb 18 2012, 05:55 PM
somd914   I'm in for the $30 kit. PM sent as follo...   Feb 19 2012, 09:09 PM
41 User(s) are reading this topic (41 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 28th December 2024 - 02:40 AM
