Tom |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None ![]() |
EDIT: 3/06/13
I won't be providing these kits any longer. I apologize to the members who have been waiting. Please feel free to use any info in the thread to help you come up with a fuse solution that meets your individual needs. Parts list on last page. Tom NEW INFO FOR EARLY CARS. THEY CAME WITH ONLY THREE RED WIRES!! Two 4.0mm and a much larger wire running forward to the dash area. Please check before ordering. Last round this summer. Maybe next winter I will do this again if there is a demand. See pics of the new 4-way and 6-way kits, and the completed install of mine. Kits are designed to go on the outer edge of the battery box, however some have mounted elsewhere. If you have need for longer wires so you can mount yours differently, let me know and we can make that work for you. Also, please see the two pages of info below. You should be able to print copies. From the supplier: 4/6 individually fused circuits with connections that enter and exit from the bottom allow this fuse block to be mounted in narrow locations. Clear plastic dust cover is included. Max load capacity for all circuits combined is 50 amps, 65 amps for the 6-way. Connections are made using 1/4" female push-on connectors. I will open round four as I already have 3 folks who want one. There will be two models, a 4-way and a 6-way, and three stages; 1-basic, 2-connections on and soldered, 3 - with new battery connector. 4-way stage 1- basic kit $25.00 stage 2- connectors on and soldered and harness heat shrinked $30.00 stage 3- With new battery connector $32.00 6-way stage 1- basic kit $30.00 stage 2- connectors on and soldered and harness heat shrinked $35.00 stage 3- With new battery connector add $37.00 I will leave this open until 5 June, them order parts. It looks from the last round that you can expect about a month to receive the kit. IE: if I order parts by 6 June, the kits will ship no later than 30 June. . Attached thumbnail(s) ![]() ![]() ![]() ![]() ![]() ![]() |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
seems like there are two people in this thread that had burned wiring without a good fuse solution in place.
One of the guys has 4 wiring setups that melted. Seems like a very valid idea. Rich |
Lo-Fi Version | Time is now: 25th June 2024 - 07:43 PM |
