Valy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California ![]() |
I got a spare engine with my car. The engine looks nice but the PO drained the oil out and left the sump open. Then he wrapped it in plastic wrap and dropped the engine on the left head so it has a nice crack.
Got myself a new pair of heads that are rebuilt right now. It's going to be a big L-Jet as I don't have the patience to deal with the old D-Jet (although I have all the parts for a D-Jet). I I'm going to make it a 2056cc unless in change my mind and go crazy with a bigger crank (IMG:style_emoticons/default/idea.gif) I started taking the engine apart and going to document as much as I can. Not my first rebuild but is my first Type4 rebuild so wish me luck! Today I got pistons 3 & 4 out. #3 looks nice, not too much signs of wear. The ring gaps are about 1mm (trash) #4 is also nice but the piston got a small bent while trying to remove the pin. That bent trapped the oil ring. Never mind, I'm going for bigger one anyway. The cylinder registers are nice. In fact, the entire case is very nice and clean. Anyone knows the meaning of the inscriptions on the cylinders and pistons? ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,146 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Piston writing: 93.97 == diameter in mm. That's what fits correctly in the 94mm cylinders. The arrow points toward the flywheel, I think. Not sure about the rest of the writing, but it looks like a stock piston.
Pushrod wear: Someone didn't get the tube retaining wire in place on that cylinder. The hard steel wire rubbed on the soft aluminum, producing the wear you see there. We have seen pushrods notched from this sort of thing. --DD |
Valy |
Piston writing: 93.97 == diameter in mm. That's what fits correctly in the 94mm cylinders. The arrow points toward the flywheel, I think. Not sure about the rest of the writing, but it looks like a stock piston. Pushrod wear: Someone didn't get the tube retaining wire in place on that cylinder. The hard steel wire rubbed on the soft aluminum, producing the wear you see there. We have seen pushrods notched from this sort of thing. --DD I guess I can reuse that pushrod, correct? It's only 0.06mm off the sidewall. |
Lo-Fi Version | Time is now: 19th April 2025 - 08:25 AM |
