siverson |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,458 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California ![]() ![]() ![]() |
I've been slowly sorting through the mess I made for myself about a month ago at Willow Springs, and have 1 quote to fix the dent.
I'm trying to decide between (A) repairing my chassis, and (B) getting a new chassis and moving all my parts over. I feel ridiculous even considering scrapping my chassis when I see some of the crazy "rustoration" threads here, but the fact is it's probably going to be about the same cost to straighten this chassis versus buying a donor chassis/car and building it back up. I'm going to take this "opportunity" to fix/improve some other things on the car while I have it all apart, but I need to figure out my chassis plan first. Here are my options: A: If I repair my current chassis ($10k - $12k): - Find front clip - Remove Brad Meyeur kit (to be replaced with Engman kit) - Remove/cut existing reinforcing tubes - Celette bench, weld new clip - Fix front right fender/flare (it was also damaged, that strut broke) - Add Engman kit - Add back reinforcement B: Build up a donor car/chassis and move over all my parts ($10k - $15k): - Find a donor car/chassis - Remove all rust/prep chassis. Rust repairs. - Add 4 steel GT flares - Maybe also put this one on a Celette bench first too to make sure it's straight. - Add Engman kit - Add chassis reinforcement - Lots of small modifications I had already made: lower drivers floor/seat, close up a bunch of unused holes/make it cleaner, lots of seam welding, dash modifications, etc, etc ... plus full R&R on the front suspension/etc, but I need to do that regardless of my chassis plan. With A it "my" original car, but with B I actually think I might end up with a nicer end result because I'm going through almost everything again, but it's probably a little more money and A LOT more work for me (versus 95% of A is just me writing a check). Am I off on my prices? So, what do you think? A or B? (IMG:style_emoticons/default/sad.gif) -Steve p.s. And... the other strange factor is that this car/chassis was my first car and I've had it for almost 20 years. (IMG:style_emoticons/default/sad.gif) But, given how much I've already modified the car, most of those "original" parts aren't there anyways. I think if I got a new chassis and moved over all my parts, it would still feel pretty much like "my" car... I'm not super attached to that specific VIN... Or am I? (IMG:style_emoticons/default/confused24.gif) ![]() ![]() |
0396 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California ![]() |
All the best with either decision...It was great seeing you at the event...maybe next time I will be running with you in the fast group.
Lo-Fi Version | Time is now: 18th April 2025 - 05:06 AM |
