Distributer Exploded, Have you seen this before? And do you have a spare? |
Millerwelds |
Sep 7 2011, 02:37 PM
Pleepleus Group: Members Posts: 723 Joined: 24-June 08 From: Grass Valley, CA Member No.: 9,206 Region Association: Northern California |
2.0 Djet. I changed out the plate due to a disconnected ground about a year ago and cleaned and lubed everything at that time. It has worked fine since then, til yesterday. Went to start the car and it did not sound right. Then no spark. Fiddled with a few things to make sure the wiring on the coil did not rattle loose etc, tried again and the distributer rotated 180 degrees and exposed this fancy new hole.
(IMG:style_emoticons/default/ar15.gif) Towed it home and dismantled the distributer this morning to find the following. It had been wearing away for a while based on the metal shavings. The shavings are not brass / bronze from the normal wear of the rotor /cap. Notice the wear on the FI trigger points plate too Part numbers for reference Here is a picture of the car for good measure. She looks real good (sitting in the garage!) (IMG:style_emoticons/default/headbang.gif) |
green71 |
Sep 7 2011, 10:41 PM
Newbie Group: Members Posts: 2 Joined: 12-August 11 From: United States Member No.: 13,435 Region Association: None |
My car did the same thing -- shot the piece clean through the side of the distributor housing -- but not before it stove up the distributor altogether . . . which stopped the distributor drive shaft, which is driven by a BRASS gear on the crankshaft (or camshaft, don't recall for sure). The brass gear lost the fight, and I wound up with brass chunks and shavings in my engine case and a good reason to do an engine rebuild. You should try to get a look at that gear to see if it suffered any damage; you wouldn't want that stuff sloshing around in your engine.
Mark |
Lo-Fi Version | Time is now: 6th January 2025 - 03:11 PM |
