Broken odometer, Fixing by who or replacing with current milage? |
eyecolor |
Sep 7 2011, 06:32 PM
Eyecolor Group: Members Posts: 80 Joined: 15-August 08 From: Wilmington,DE Member No.: 9,425 Region Association: None |
I don't want to run into trouble with inspection time here in Delaware.
The odometer portion is stuck and I need to have it repaired or replaced. I certainly don't want to be accused of "setting back" the milage. What are my options? |
Dave_Darling |
Sep 8 2011, 05:05 PM
914 Idiot Group: Members Posts: 15,051 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
If the speedo is working, the speedo drive (the angle drive and the cable) is working. It's a relatively common failure for the odometer to stop counting; it is generally caused by a pot-metal gear inside the odo starting to slip on its shaft. It is originally pressed on, but the pot-metal deforms over the years, especially if the odo is reset while the car is moving.
--DD |
Lo-Fi Version | Time is now: 31st October 2024 - 08:21 PM |
