> Distributer Exploded, Have you seen this before? And do you have a spare?
Millerwelds
post Sep 7 2011, 02:37 PM
Pleepleus
2.0 Djet. I changed out the plate due to a disconnected ground about a year ago and cleaned and lubed everything at that time. It has worked fine since then, til yesterday. Went to start the car and it did not sound right. Then no spark. Fiddled with a few things to make sure the wiring on the coil did not rattle loose etc, tried again and the distributer rotated 180 degrees and exposed this fancy new hole.
Attached Image (IMG:style_emoticons/default/ar15.gif)
Towed it home and dismantled the distributer this morning to find the following.
It had been wearing away for a while based on the metal shavings. The shavings are not brass / bronze from the normal wear of the rotor /cap.
Notice the wear on the FI trigger points plate too
Part numbers for reference
Here is a picture of the car for good measure. She looks real good (sitting in the garage!) (IMG:style_emoticons/default/headbang.gif)
green71
post Sep 8 2011, 11:41 PM
bigkensteele is right about splitting the case. The brass drive gear is tatered now after its run-in with the steel drive shaft. Even if you could flush the chunks & shavings out of the engine, the two gears might not engage in a trustworthy manner. Judging from how my drive gear looked when I removed it, the poor fit between the gears would lead to more brass shavings over a prolonged period, meaning you might have to replace a bunch of parts instead of just one.
Stiff upper lip! This is an opportunity. Go kick its butt.
Mark
Millerwelds   Distributer Exploded   Sep 7 2011, 02:37 PM
76-914   Damn, interesting. :WTF:   Sep 7 2011, 02:49 PM
windforfun   Try Rich at HPH in Redwood City: http://www.highp...   Sep 7 2011, 03:21 PM
HAM Inc   Damn! Looks like it threw a rod! Can...   Sep 7 2011, 05:07 PM
Cap'n Krusty   Damn! Looks like it threw a rod! Can...   Sep 7 2011, 05:34 PM
rdauenhauer   I have as well, it didnt hit hard enough to blow o...   Sep 7 2011, 06:53 PM
KELTY360   I have as well, it didnt hit hard enough to blow ...   Sep 7 2011, 10:19 PM
Sleepin   I have one. Here it is. Let me know if it will wor...   Sep 7 2011, 07:32 PM
kwales   Jup, Bosch distributors do that. Blew one in my ...   Sep 7 2011, 09:08 PM
green71   My car did the same thing -- shot the piece clean ...   Sep 7 2011, 10:41 PM
Millerwelds   My car did the same thing -- shot the piece clean...   Sep 8 2011, 03:52 PM
cwpeden   Actually the bottom 1/4 of your drive is ok. That ...   Sep 8 2011, 07:36 PM
bigkensteele   Looks like you might owe Mark a beer. It would ap...   Sep 8 2011, 07:53 PM
green71   bigkensteele is right about splitting the case. Th...   Sep 8 2011, 11:41 PM
Millerwelds   bigkensteele is right about splitting the case. T...   Sep 9 2011, 09:26 AM
Valy   I guess I will be splitting the case. I am tremen...   Sep 9 2011, 10:15 AM
r_towle   bigkensteele is right about splitting the case. ...   Sep 13 2011, 08:56 AM
Millerwelds   Since I have to tear this apart I am thinking larg...   Sep 13 2011, 04:31 PM
Thestigz06   2.0 Djet. I changed out the plate due to a disco...   Sep 13 2011, 01:04 AM
Millerwelds   Totally random but could you tell me the tire siz...   Sep 13 2011, 08:00 AM
Thestigz06   Totally random but could you tell me the tire si...   Sep 13 2011, 01:55 PM
Drums66   ......Never seen that before...don't care to :...   Sep 13 2011, 03:58 PM
9 User(s) are reading this topic (9 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 03:42 PM
