yeahmag |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,424 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California ![]() ![]() |
I'm looking to relocate my oil cooler to the front of the car, so I need big lengths of -10 AN hose. Let me know what you have...
-Aaron |
markb |
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California ![]() ![]() |
Better to find out what kind of deal we can give you, so you have a frame of reference, right?
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,549 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Contact a hydraulic supply that sells hoses and fittings. Check with GPR too.
You can also use A/C pressure hose. What engine are you running and how far is the hose run? You may not need -10 hose. -8 is satisfactory for many applications. You only need a medium duty hose that has a minimum of 150 PSI rating. How much hose do you need? Also price the fittings as they too are costly. The swedged on ferell fitting are less costly. Stay away from the external SS hose. It is more for looks. The wire braid does more good inside of the hose. Give me a call at 951 536 7478. I worked for an oil cooler company for 27 years and picked up a little knowledge when I was there about plumbing oil coolers. Bruce |
Lo-Fi Version | Time is now: 26th June 2024 - 05:40 AM |
