> Distributer Exploded, Have you seen this before? And do you have a spare?
Millerwelds
post Sep 7 2011, 02:37 PM
Pleepleus
2.0 Djet. I changed out the plate due to a disconnected ground about a year ago and cleaned and lubed everything at that time. It has worked fine since then, til yesterday. Went to start the car and it did not sound right. Then no spark. Fiddled with a few things to make sure the wiring on the coil did not rattle loose etc, tried again and the distributer rotated 180 degrees and exposed this fancy new hole.
Attached Image (IMG:style_emoticons/default/ar15.gif)
Towed it home and dismantled the distributer this morning to find the following.
It had been wearing away for a while based on the metal shavings. The shavings are not brass / bronze from the normal wear of the rotor /cap.
Notice the wear on the FI trigger points plate too
Part numbers for reference
Here is a picture of the car for good measure. She looks real good (sitting in the garage!) (IMG:style_emoticons/default/headbang.gif)
green71
post Sep 8 2011, 11:41 PM
bigkensteele is right about splitting the case. The brass drive gear is tatered now after its run-in with the steel drive shaft. Even if you could flush the chunks & shavings out of the engine, the two gears might not engage in a trustworthy manner. Judging from how my drive gear looked when I removed it, the poor fit between the gears would lead to more brass shavings over a prolonged period, meaning you might have to replace a bunch of parts instead of just one.
Stiff upper lip! This is an opportunity. Go kick its butt.
Mark
Millerwelds
post Sep 9 2011, 09:26 AM
Pleepleus
QUOTE(green71 @ Sep 8 2011, 10:41 PM) *
Mark
I was under the impression that the drive gear on the distributer side was brass while the gear on the cam was steel. After cleaning up the distributer drive gear I now see that it is steel and shows almost no wear. Which means the trashed gear is the one on the cam. Fuch! (IMG:style_emoticons/default/sad.gif)
I guess I will be splitting the case. I am tremendously glad to have had everyone's help in figuring that out before really screwing things up.
It has been 20 years since I rebuilt a type 1 so I will have a lot of questions.
r_towle
post Sep 13 2011, 08:56 AM
Custom Member
QUOTE(Millerwelds @ Sep 9 2011, 11:26 AM) *
Mark
Its actually driven off the crankshaft.
Its not super hard to get this done.
Hunt down a good use distributor drive gear so you have it ready and after you crack the case, bring the crankshaft to the machine shop for polishing.
Part of the process is to remove the drive gears and main bearing on the end of the crank so it will mount up in the machine.
Bottom line, the machine shop can do this for you when the time comes.
If you want to, you can easily remove all the pieces with one gear splitter and a small mapp gas torch....
You will need a new gasket kit.
New main bearings
New rod bearings
New front and rear main seal.
New distributor gear for the crank.
One long weekend you can pull the motor and split the case to get the crank out.
Then get it to a shop to get polished.
You spend your nights cleaning out that case and cleaning up all the parts.
Then the following weekend, bolt it back together....
It does not need to turn into a 6 month restoration project...and its really not a huge deal to do this if you stay focused.
With these new motors and rubber bands that drive the camshafts, IC my son doing a new head job on at least one car per month...and that is a major piece of work.
They get in, get out and move on as quickly as possible.
Every head he does has bent valves, cracks...lots of damage.
Its why machine shops exist.
Just put your head down, dont dream big, and fix what got broken so you can enjoy the car (IMG:style_emoticons/default/smile.gif)
Whatever you do, dont start thinking about more power.
Rich
Millerwelds
post Sep 13 2011, 04:31 PM
Pleepleus
Since I have to tear this apart I am thinking larger cam, bigger pistons, dual 44 carbs instead of FI.... (IMG:style_emoticons/default/idea.gif)
Just kidding. Thanks Rich for the breakdown. This engine was built by SilverBullit (Jason) before he decided to go with a 6 and then decided to get out of 914's altogether (I think). Anyway he knew what he was doing and I doubt the engine has 15,000 miles on it so the plan is to take it apart and fix it and slap it back together ASAP. (IMG:style_emoticons/default/driving.gif)
Millerwelds   Distributer Exploded   Sep 7 2011, 02:37 PM
76-914   Damn, interesting. :WTF:   Sep 7 2011, 02:49 PM
windforfun   Try Rich at HPH in Redwood City: http://www.highp...   Sep 7 2011, 03:21 PM
HAM Inc   Damn! Looks like it threw a rod! Can...   Sep 7 2011, 05:07 PM
Cap'n Krusty   Damn! Looks like it threw a rod! Can...   Sep 7 2011, 05:34 PM
rdauenhauer   I have as well, it didnt hit hard enough to blow o...   Sep 7 2011, 06:53 PM
KELTY360   I have as well, it didnt hit hard enough to blow ...   Sep 7 2011, 10:19 PM
Sleepin   I have one. Here it is. Let me know if it will wor...   Sep 7 2011, 07:32 PM
kwales   Jup, Bosch distributors do that. Blew one in my ...   Sep 7 2011, 09:08 PM
green71   My car did the same thing -- shot the piece clean ...   Sep 7 2011, 10:41 PM
Millerwelds   My car did the same thing -- shot the piece clean...   Sep 8 2011, 03:52 PM
cwpeden   Actually the bottom 1/4 of your drive is ok. That ...   Sep 8 2011, 07:36 PM
bigkensteele   Looks like you might owe Mark a beer. It would ap...   Sep 8 2011, 07:53 PM
green71   bigkensteele is right about splitting the case. Th...   Sep 8 2011, 11:41 PM
Millerwelds   bigkensteele is right about splitting the case. T...   Sep 9 2011, 09:26 AM
Valy   I guess I will be splitting the case. I am tremen...   Sep 9 2011, 10:15 AM
r_towle   bigkensteele is right about splitting the case. ...   Sep 13 2011, 08:56 AM
Millerwelds   Since I have to tear this apart I am thinking larg...   Sep 13 2011, 04:31 PM
Thestigz06   2.0 Djet. I changed out the plate due to a disco...   Sep 13 2011, 01:04 AM
Millerwelds   Totally random but could you tell me the tire siz...   Sep 13 2011, 08:00 AM
Thestigz06   Totally random but could you tell me the tire si...   Sep 13 2011, 01:55 PM
Drums66   ......Never seen that before...don't care to :...   Sep 13 2011, 03:58 PM
10 User(s) are reading this topic (10 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 03:43 PM
