mark21742 |
Member ![]() ![]() Group: Members Posts: 162 Joined: 31-August 11 From: pa Member No.: 13,502 Region Association: North East States ![]() |
Just curious if anyone has dropped a newer (mid 90s) Honda Civic engine in a 914?
I have a 96 1.6l engine, harness, fuel injection, all hardware and also have a turbo charger laying in the corner of the garage..... The combo should put down a very reliable 250 hp and just had the gears turning in my head about the thought of it. |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
The 911 transmissions spin the "wrong" way already for a 914. The problem is that they are designed to have the input spin one direction--flipping the diff only changes the direction of the output. The internal bits are designed to spin one direction, and they generally will be less happy when spun the other way.
Corvair engines spin the "wrong" way as well, and the general solution for putting them into VWs or 914s or what have you is to rebuild the engine with a "reverse rotation cam" so that the engine spins the other way. You can use a 911 transmission (901, 915, 930, G50, etc.) without flipping the R&P with the B-series Honda engine. (One Rennlist member ran an unmodified Corvair motor and a 912 transmission, at least for a while.) But the durability of the transmission will be a real question. --DD |
Lo-Fi Version | Time is now: 28th June 2024 - 12:52 AM |
