anyone swap in a honda engine? |
mark21742 |
Sep 19 2011, 09:32 AM
Member Group: Members Posts: 162 Joined: 31-August 11 From: pa Member No.: 13,502 Region Association: North East States |
Just curious if anyone has dropped a newer (mid 90s) Honda Civic engine in a 914?
I have a 96 1.6l engine, harness, fuel injection, all hardware and also have a turbo charger laying in the corner of the garage..... The combo should put down a very reliable 250 hp and just had the gears turning in my head about the thought of it. |
Andyrew |
Sep 23 2011, 08:32 AM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Shift and clutch linkage is easy. You could go with a hydraulic clutch and use the stock hydraulic clutch setup, Or you could keep it cable and go that route. Shifting should be done via cable. The honda setup is PERFECT for a cable system.
Also you could easily keep the front trunk, And some of the rear trunk (Basically enough to throw tools, a jacket and the targa top). Like I said you only have to deal with the radiator, and you could easily go with a 1/2 radiator and if you really wanted to you could mount it in front of one of the rear fenders and make a cutout. Using a fan you would have all the cooling you need, the honda engines run REALLY cool. |
Lo-Fi Version | Time is now: 28th September 2024 - 09:11 AM |
