larss |
Member ![]() ![]() Group: Members Posts: 428 Joined: 10-September 09 From: Sweden Member No.: 10,787 Region Association: Scandinavia ![]() |
If I don't fit any gasket at the top of the cylinders (which is what every expert suggests) will this affect the type/thickness of shim used at the bottom or is the increase in compression so marginal that standard shims can be used?
This is for a all standard 1,7 D-jet engine rebuild. /Lars |
larss |
Thanks guys, this made things clear to me!
Just discovered another issue: Valve seats for #2 cyl are not flush with the head surface (as all the other are) they are inset (dropped?) about 0,05mm. Is this what they call "dropped valve seats" and should i dump this head? I guess fitting new seats is no good since they will go in as far as te old ones and the problem will remain? /Lars S |
Lo-Fi Version | Time is now: 2nd July 2024 - 03:48 PM |
