Tdc with no viewing ports? |
Radmacdaddy |
Oct 10 2011, 12:23 AM
Member Group: Members Posts: 83 Joined: 28-September 11 From: United States Member No.: 13,617 Region Association: None |
I'm viewing the great valve adjustment article over at pelican & have my one wheel off the ground to get it just right but I have no viewing ports into my flywheel.
How then can I get the tdc worked out? I did the straw in the #1 cylinder trick too, put it in & note when it is most pushed out and before it goes back into the chamber... But it still feels like its not just right. Thought? |
r_towle |
Oct 10 2011, 09:13 AM
Custom Member Group: Members Posts: 24,680 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
It not possible to install the distributor 180 degrees off.
It is possible to install the distributor drive gear 180 degrees off. The piston comes up top twice.... Turn the motor so the rotor points to that notch. See what the valves look like on number one cylinder. No firing on 3/4 might be fuel related....clean that carb's jets. Rich |
Lo-Fi Version | Time is now: 6th January 2025 - 05:39 PM |
