Tdc with no viewing ports? |
Radmacdaddy |
Oct 10 2011, 12:23 AM
Member Group: Members Posts: 83 Joined: 28-September 11 From: United States Member No.: 13,617 Region Association: None |
I'm viewing the great valve adjustment article over at pelican & have my one wheel off the ground to get it just right but I have no viewing ports into my flywheel.
How then can I get the tdc worked out? I did the straw in the #1 cylinder trick too, put it in & note when it is most pushed out and before it goes back into the chamber... But it still feels like its not just right. Thought? |
jcd914 |
Oct 14 2011, 01:19 AM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
You're not likely to have good compression on a fresh assembly, the rings need to seat to the cylinders. As hard as it may be to do, you need to drive it easy for a few hundred miles while it breaks in.
Good luck. Jim |
Lo-Fi Version | Time is now: 6th January 2025 - 05:52 PM |
