Valy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California ![]() |
I got a spare engine with my car. The engine looks nice but the PO drained the oil out and left the sump open. Then he wrapped it in plastic wrap and dropped the engine on the left head so it has a nice crack.
Got myself a new pair of heads that are rebuilt right now. It's going to be a big L-Jet as I don't have the patience to deal with the old D-Jet (although I have all the parts for a D-Jet). I I'm going to make it a 2056cc unless in change my mind and go crazy with a bigger crank (IMG:style_emoticons/default/idea.gif) I started taking the engine apart and going to document as much as I can. Not my first rebuild but is my first Type4 rebuild so wish me luck! Today I got pistons 3 & 4 out. #3 looks nice, not too much signs of wear. The ring gaps are about 1mm (trash) #4 is also nice but the piston got a small bent while trying to remove the pin. That bent trapped the oil ring. Never mind, I'm going for bigger one anyway. The cylinder registers are nice. In fact, the entire case is very nice and clean. Anyone knows the meaning of the inscriptions on the cylinders and pistons? ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Yup, use the tabs and pry it off. I'm sure someone out there has damaged a case doing that, but use your head and pry carefully and you'll be fine.
You know you gots a bus case there? Not that it matters much, but that blocked off passage just above the taco plate is where the bus dipstick and oil filler tube go. |
Valy |
Yup, use the tabs and pry it off. I'm sure someone out there has damaged a case doing that, but use your head and pry carefully and you'll be fine. You know you gots a bus case there? Not that it matters much, but that blocked off passage just above the taco plate is where the bus dipstick and oil filler tube go. The case is a generic Type4 one. It has a strange SN on it and looks like it's a replacement case. Otherwise the case looks nice and clean without too much wear. I don't see any problem with it being specked initially for a bus. Here is a picture of the SN. (IMG:http://www.914world.com/bbs2/uploads/post-11573-1314680829.jpg) |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,717 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
Yup, use the tabs and pry it off. I'm sure someone out there has damaged a case doing that, but use your head and pry carefully and you'll be fine. You know you gots a bus case there? Not that it matters much, but that blocked off passage just above the taco plate is where the bus dipstick and oil filler tube go. The case is a generic Type4 one. It has a strange SN on it and looks like it's a replacement case. Otherwise the case looks nice and clean without too much wear. I don't see any problem with it being specked initially for a bus. Here is a picture of the SN. Speced for a bus is 100% fine. Mark is correct about the oil temp sensor location. The 914 unit will not fit. The modern 2 1/16 sender will fit, but you have to use the modern gauge. Zach |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Yup, use the tabs and pry it off. I'm sure someone out there has damaged a case doing that, but use your head and pry carefully and you'll be fine. You know you gots a bus case there? Not that it matters much, but that blocked off passage just above the taco plate is where the bus dipstick and oil filler tube go. The case is a generic Type4 one. It has a strange SN on it and looks like it's a replacement case. Otherwise the case looks nice and clean without too much wear. I don't see any problem with it being specked initially for a bus. Here is a picture of the SN. Speced for a bus is 100% fine. Mark is correct about the oil temp sensor location. The 914 unit will not fit. The modern 2 1/16 sender will fit, but you have to use the modern gauge. Zach I don't see any comments about temperature sensor location in any post other than yours. The type of case has NOTHING to do with oil temp sensor fitment, and the stock one will fit fine. Second time I've seen this misguided notion in the last few days ................ The Cap'n |
McMark |
I don't see any comments about temperature sensor location in any post other than yours. The type of case has NOTHING to do with oil temp sensor fitment, and the stock one will fit fine. Second time I've seen this misguided notion in the last few days ................ The Cap'n You're right, I didn't mention that. Zach was reading my mind. There ARE some cases which won't fit a stock 'long' oil temp sensor probe. Ran into that problem on a bus once. (IMG:style_emoticons/default/hijacked.gif) |
Cap'n Krusty |
I don't see any comments about temperature sensor location in any post other than yours. The type of case has NOTHING to do with oil temp sensor fitment, and the stock one will fit fine. Second time I've seen this misguided notion in the last few days ................ The Cap'n You're right, I didn't mention that. Zach was reading my mind. There ARE some cases which won't fit a stock 'long' oil temp sensor probe. Ran into that problem on a bus once. (IMG:style_emoticons/default/hijacked.gif) The temp sensor installation shown in the picture is aftermarket. With the correct taco plate, the long sensor will fit in ANY T4 case. In that part of the case, they're ALL the same. The Cap'n |
McMark |
The temp sensor installation shown in the picture is aftermarket. With the correct taco plate, the long sensor will fit in ANY T4 case. In that part of the case, they're ALL the same. The Cap'n Sorry Cap'n. You lose this round. (IMG:style_emoticons/default/tongue.gif) Case on the left is a GE case and the long sensor will bump into that 'skirt/fin' hanging down. BTDT. Attached image(s) ![]() ![]() |
Lo-Fi Version | Time is now: 19th April 2025 - 08:25 AM |
