Series9 |
Lesbians taste like chicken. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States ![]() |
I have a Boxster customer with a brake problem. She's had the car for 140k miles and has taken it with her to Hawaii and back.
Late in August, she experienced a very strange brake failure about 50 yards from her driveway. The pedal went to the floor. She stopped with the parking brake. Immediately after stopping, the brakes worked normally again. She took the car to her old mechanic, who replaced the master cylinder. Last week, it happened again. This time, she was going 45 and had to swerve to miss traffic. She ended up in the grass, facing the other way by the time she stopped. Once again, the brakes were back immediately and she drove home. When she returned to her mechanic, he told her the car was a liability and said he couldn't help her any more. That's when she found me. There are no fault codes stored or active for the ABS and she is now afraid of the car. She wants to keep it, though. She's a school teacher who can't afford the $4000+ bill to replace the ABS (if that were to become necessary). We have discussed bypassing the ABS hydraulically, but I told her I have ethical questions I have to ponder before doing so. I would like your opinions, please. |
flipb |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,734 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region ![]() ![]() |
A quick web search turned up this similar story.
http://www.planet-9.com/cayman-boxster-com...ntrol-unit.html Rather than alter the system, could she achieve the same effect if you subtly recommended that she pull the ABS fuse? |
Series9 |
A quick web search turned up this similar story. http://www.planet-9.com/cayman-boxster-com...ntrol-unit.html Rather than alter the system, could she achieve the same effect if you subtly recommended that she pull the ABS fuse? Maybe, but the car will continually harass her that the ABS is not functional. |
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
A quick web search turned up this similar story. http://www.planet-9.com/cayman-boxster-com...ntrol-unit.html Rather than alter the system, could she achieve the same effect if you subtly recommended that she pull the ABS fuse? Maybe, but the car will continually harass her that the ABS is not functional. I wouldn't do it. Why stick your neck out modifying a stock break system. It seems you have enough work on your plate without this. Think of it in aviation terms. What happens when you modify an existing design on your airplane without authorization from the manufacturer or our friends at the FAA? Would Porsche authorize this mod.? |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,516 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
A quick web search turned up this similar story. http://www.planet-9.com/cayman-boxster-com...ntrol-unit.html Rather than alter the system, could she achieve the same effect if you subtly recommended that she pull the ABS fuse? Maybe, but the car will continually harass her that the ABS is not functional. I wouldn't do it. Why stick your neck out modifying a stock break system. It seems you have enough work on your plate without this. Think of it in aviation terms. What happens when you modify an existing design on your airplane without authorization from the manufacturer or our friends at the FAA? Would Porsche authorize this mod.? (IMG:style_emoticons/default/agree.gif) I got to hang with Elliot on this one. Don't do it Joe. |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:46 PM |
