Gas tank interchangeability |
Harpo |
Oct 23 2011, 12:48 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Can early & late gas tanks be swapped? After I saw this photo of a hood with a hole cut in it for the gas cap I want to do this with my car. A chromed early cap would look a lot better than the late plastic cap. What do you think?
Attached image(s) |
914werke |
Oct 23 2011, 02:30 PM
"I got blisters on me fingers" Group: Members Posts: 10,540 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
yes & no.
If you swap the entire unit yes. if you just want to swap the expansion & filler assembly No. The steel expansion tank mounts differently than does the plastic version on the later tank. |
jaxdream |
Oct 23 2011, 02:35 PM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
yes & no. If you swap the entire unit yes. if you just want to swap the expansion & filler assembly No. The steel expansion tank mounts differently than does the plastic version on the later tank. Ok , I didn't know that , it was my plan to use a plastic filler housing / expansion tank on an earlier tank. Well now plan B...... Jack |
Lo-Fi Version | Time is now: 24th September 2024 - 12:57 PM |
