pgeorgeson |
Newbie ![]() Group: Members Posts: 22 Joined: 23-October 11 From: Reno, NV Member No.: 13,710 Region Association: None ![]() |
I just bought a 1974 2.0 and am having a fuel delivery issue.
I am not getting any output from my fuel pump. There is fuel supply to the pump (into the S port) from the tank and through the filter. I removed the output line ("D" port -- the middle one) and attached a test line feeding the test line into a bottle. When the pump runs, I am not getting any fuel out of my test line from the D port. I can hear it going "pssst, pssst, pssst," but no fuel ever comes out. In addition, although it isn't sending fuel out of the D port, it seems to be pumping fuel into the return line. The reason I can tell this is that when I removed all the lines from the pump, fuel drained out of the return line where the return line attaches to the R port. After I did my test, I removed the all the lines again (to switch pumps) and quite a bit of fuel again came out of the R line again. I have a spare pump that I got from the previous owner, and both appear to be doing exactly the same thing. It seems like both pumps are pumping fuel into the R line instead of the D line. What is going on and how to I fix it or test it? |
pgeorgeson |
Thanks for the ideas. I have not taken the pump apart. I was thinking that there could be some blockage to the D port, but then it seems like I wouldn't hear it trying to pump (the pssst, pssst, pssst). I will check the wiring first, then maybe open up the pump next. I was also thinking I will attach a test hose to the R line to see if it is really pumping out of that line.
I have checked the lines to the engine, and everything is where it is supposed to be. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:30 AM |
