Help with a fuel pump issue |
pgeorgeson |
Oct 23 2011, 09:16 PM
Newbie Group: Members Posts: 22 Joined: 23-October 11 From: Reno, NV Member No.: 13,710 Region Association: None |
I just bought a 1974 2.0 and am having a fuel delivery issue.
I am not getting any output from my fuel pump. There is fuel supply to the pump (into the S port) from the tank and through the filter. I removed the output line ("D" port -- the middle one) and attached a test line feeding the test line into a bottle. When the pump runs, I am not getting any fuel out of my test line from the D port. I can hear it going "pssst, pssst, pssst," but no fuel ever comes out. In addition, although it isn't sending fuel out of the D port, it seems to be pumping fuel into the return line. The reason I can tell this is that when I removed all the lines from the pump, fuel drained out of the return line where the return line attaches to the R port. After I did my test, I removed the all the lines again (to switch pumps) and quite a bit of fuel again came out of the R line again. I have a spare pump that I got from the previous owner, and both appear to be doing exactly the same thing. It seems like both pumps are pumping fuel into the R line instead of the D line. What is going on and how to I fix it or test it? |
ellisor3 |
Oct 24 2011, 06:37 AM
HPWhore Group: Members Posts: 811 Joined: 23-October 08 From: Fleming Island, Florida Member No.: 9,683 Region Association: South East States |
If you are not getting a Whirl sound, it is probably clogged. Pull the pump and run it straight off the battery. You can try cleaning it with either diesel as mentioned or spray some brake cleaner in the pump. Try running it forward and then reverse the polarity and run it backwards. If it is clogged, then find out why, it you have trash in your tank, you may find yourself on the side of the road at some point, I can tell you from experience.
Lo-Fi Version | Time is now: 25th September 2024 - 10:41 PM |
