Gas tank interchangeability |
Harpo |
Oct 23 2011, 12:48 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Can early & late gas tanks be swapped? After I saw this photo of a hood with a hole cut in it for the gas cap I want to do this with my car. A chromed early cap would look a lot better than the late plastic cap. What do you think?
Attached image(s) |
jaxdream |
Oct 26 2011, 09:11 AM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
rdauenhauer is right , but if you mod the early tank vs the late tank ( with the platic fill / expn tank ), you can install the later plastic expansion tank and cap system. See pics of early tanks , they have a tab on the end that the steel xpn tank bolts to , also tabs for the charcoal canitster . A simple mod to the middle tab would make it possible to mount the plastic on the early tank.The bolt patterns of both tank mountings is the same , just the xpn tank mountings is different. To mount the late plastic xpn tank to the early tank ,you need to cut the tab off the end of tank , and fab a mount for the middle of tank to secure the inboard end of the plastic xpn tank .
Jack |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:36 PM |
