deloreandude86 |
Austin Burkhardt ![]() ![]() Group: Members Posts: 61 Joined: 18-August 10 From: Austonio, TX Member No.: 12,068 Region Association: South East States ![]() |
Hey guys, I was reading the other day that if you do a carb conv. that you also need a new cam. Was wondering exactly what cam i need and if it will be cheaper just to fix the FI, because I have the new dual carb system and the old FI which needs to be totally re-worked, all components need to be replaced. I have a 1.7.
Thanks |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
All your FI components need to be replaced? I seriously doubt that. There are a lot of here that have what you need. If your gonna split the case to replace the cam, your also gonna put in all new bearings, have the crank polished, bigger pistons and cylinders, etc. It always happens. Its the "while I'm in there syndrom (better known as Dirk Wrights desease). Leave the cam and you will be fine, or....Just fix the FI!
Lo-Fi Version | Time is now: 25th June 2024 - 12:14 AM |
