> Trailing a 914 WITHOUT a trailer?????, How to do it??? plus or negatives??
Mueller
post Apr 29 2004, 11:27 AM
914 Freak!
At the Marina Auto-x, Ken Holladay (sp?) towed his car to the event behind his RV (I would think anything with the towing capacity would work)
Ken or anyone else that does this, can you share some details or tips or pictures on how you setup the car and the supporting hardware???
I have a trailer, but sometimes it would be nice to tow the car without having to use the trailer.
Thanks
Howard
post Apr 29 2004, 06:27 PM
Incontin(g)ent Member
As usual with my projects, I goofed and mounted plates too far apart. Thought it said max 46" separation but it was 41". Reading comprehension!!! A few rubber plugs and skinned knuckles later, all is well. Brackets fit easily behind grills, so no cosmetic problem.
Nice 'u-joint' setup on towed end. Eliminates need to mount on a perfectly flat area. Now to FLAPS for light wiring. Can I tap into the 914 tail and brake lights?
Mueller   Trailing a 914 WITHOUT a trailer?????   Apr 29 2004, 11:27 AM
seanery   Mike, There is a guy named Chuck Atkins that tows...   Apr 29 2004, 11:33 AM
Demick   I've considered making a flat tow setup like t...   Apr 29 2004, 11:40 AM
URY914   I use to flat tow my car all over the place. Used...   Apr 29 2004, 11:49 AM
Howard   Interesting, that's my today project. Bought ...   Apr 29 2004, 11:59 AM
Howard   And the target..   Apr 29 2004, 12:00 PM
!   I sent Wattboy a towbar...dunno if he ever used it...   Apr 29 2004, 12:06 PM
URY914   The problem is the sheet metal behind the bumper i...   Apr 29 2004, 12:29 PM
!   I mounted it with a plate behind the t-bar mounts.   Apr 29 2004, 12:31 PM
Mueller   are there limitations with regards to turning or b...   Apr 29 2004, 12:50 PM
URY914   Yes, you can only back up if you're very strig...   Apr 29 2004, 01:05 PM
richardL   Would it hurt a car with a limited slip or locked ...   Apr 29 2004, 01:17 PM
TimT   FWIW my flat trailer with tirerack has just been p...   Apr 29 2004, 02:39 PM
KenH   My "tow bar" attachment hardware goes thru the gri...   Apr 29 2004, 02:54 PM
jonwatts   Yes mikez sent me a VW towbar and Brad helped me m...   Apr 29 2004, 03:32 PM
Howard   As usual with my projects, I goofed and mounted pl...   Apr 29 2004, 06:27 PM
Howard   Pic 2   Apr 29 2004, 06:28 PM
STL914   Howard, I really like your set up. :clap: Would ...   Apr 29 2004, 07:55 PM
URY914   Very nice :D Paul   Apr 29 2004, 07:56 PM
jonwatts   Howard, you should get some Porsche Cayenne badges...   Apr 29 2004, 08:02 PM
Howard   Thanks for the kind words. John, I did look at the...   Apr 30 2004, 12:57 AM
Rgreen914   Somebody please explain this "flat-towing" rage th...   Apr 30 2004, 01:12 AM
Kevin@ojai.net   I haven't flat towed since this: http://ojai.n...   Apr 30 2004, 01:40 AM
STL914   Howard, It all looks simple enough. I went to the...   Apr 30 2004, 05:42 AM
URY914   Rgreen914, A trailer can be a PITA. You have to m...   Apr 30 2004, 07:27 AM
Demick   Hope you put some backing plates behind those brac...   Apr 30 2004, 08:31 AM
James Adams   I built one that bolts to the front suspension mou...   Apr 30 2004, 08:47 AM
Demick     Apr 30 2004, 09:27 AM
porschenut   I am setting up a 76 for flat tow, I welded the bu...   Apr 30 2004, 10:58 AM
Mueller   I already have a trailer, it's a storage issue...   Apr 30 2004, 12:17 PM
Howard   No replacement for a trailer, but it is handy. I...   Apr 30 2004, 12:34 PM
Otmar   I'm surprised, I thought it was only the Elect...   Apr 30 2004, 02:02 PM
- Lo-Fi Version Time is now: 6th January 2025 - 04:56 PM
