Engine idle raise drop, cold… DJet help., up/down/up/down.... |
broomhandle |
Oct 27 2011, 11:03 AM
Member Group: Members Posts: 290 Joined: 26-June 09 From: Half Moon Bay, CA Member No.: 10,512 Region Association: Northern California |
My 1.7 when started, the idle will go up and down, even for about an hour of driving. After an hour (here or there) the idle stays up and drops for awhile. And then it is fine… but can drop back down sometimes. On hotter days, it seems like it is faster to a normal running idle. I had 4 ideas: 1.)Cold temp sensors, I know there are 2 but I am unsure about it. Or how to test. 2.)Fuel/vacuum. This was my 1st thought, so I have new lines around the motor and the top of the tank. And the injectors have been re-built. but still could be djet. 3.)I have a really old muffler that needs replacing. warms up, can breate... 4.)Air in. (I know ill start some fights here, but it has the oil mess, I swear it can not get enough air) Any ideas? It’s a daily driver, and it is annoying as heck. |
McMark |
Oct 27 2011, 11:30 AM
Vacuum leaks.
r_towle |
Oct 27 2011, 12:03 PM
Custom Member Group: Members Posts: 24,624 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Vacuum leaks. That too. To expand on this. I do this to find the leak...which could be anywhere in any vacuum circuit. Remove all vacuum lines from the plenum and cap them off with rubber caps from NAPA/FLAPS, whoever. Leave just the mps vacuum line attached to the plenum. Does the problem still happen? If no... Start attaching ONE line at a time until you determine which system is creating the vacuum leak. Could be the AAR, could be the distributor, could be devel valve... Do only ONE at a time to do proper troubleshooting. Does the problem still happen with all lines off? Yes Set your TPS per the PP article. Check to ensure your MPS holds a vacuum properly and does not leak. Set your points, timing and dwell. Check and replace the injector seals (vacuum leak) Check and tighten your intake manifold to head connection (vacuum leak) Check and tighten the large rubber hoses at the intake tubes to plenum connection. Rich |
Lo-Fi Version | Time is now: 26th September 2024 - 11:47 AM |
