Floor pan rust inside! Found some in my LE, Pull your seat out & check yours |
JRust |
Oct 25 2011, 10:09 PM
914 Guru Group: Members Posts: 6,313 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Okay I was pulling my interior to install my new dash & backpad. Down by my seat hinge I see some rust around the hinge mount. It was between the sound deadening factory stuff & the mount. It started around the mount & worked it's way across. I had one tiny hole through & some spots if it hadn't been seen would have gone through. Another gift from my car sitting outside at the wrench who screwed me a while back. He just keeps giving & giving (IMG:style_emoticons/default/headbang.gif) .
So I scraped all the sound deadening off on the rear drivers side pan. I treated it with some rust stuff I have. Tonight I scraped off most the front sound deadening. It was great with the exception of a little more around the pedal. I can tell it is just surface rust but it is coming out. I plan to use bedliner to redo the floor. Then I am going to paint it L80E to match my car. Here are a few pics to check out of the area mostly scraped up. I haven't started on the passenger side but if it has the same issue I will get some before pics. What have you used to replace the sound deadening (IMG:style_emoticons/default/confused24.gif) Attached image(s) |
JRust |
Oct 27 2011, 01:00 PM
I'm going to test some bedliner product tonight on a piece of old firewall. Once it dries I will paint it & see what I think.
If I like it? I am going to use the bedliner from the ledge down to the floor. I like bedliner for sealing up the floor. The tar mat may be a better sound deadening product. I may even use the tar mat on top of that afterword. In which case I may just order the 2 front pieces of the stock stuff. Just kind of in a hurry to finish the floor. Getting something shipped in a timely manner can be a problem. |
Lo-Fi Version | Time is now: 6th January 2025 - 04:35 PM |
