broomhandle |
Member ![]() ![]() Group: Members Posts: 290 Joined: 26-June 09 From: Half Moon Bay, CA Member No.: 10,512 Region Association: Northern California ![]() |
Engine idle raise drop, cold… DJet help.
My 1.7 when started, the idle will go up and down, even for about an hour of driving. After an hour (here or there) the idle stays up and drops for awhile. And then it is fine… but can drop back down sometimes. On hotter days, it seems like it is faster to a normal running idle. I had 4 ideas: 1.)Cold temp sensors, I know there are 2 but I am unsure about it. Or how to test. 2.)Fuel/vacuum. This was my 1st thought, so I have new lines around the motor and the top of the tank. And the injectors have been re-built. but still could be djet. 3.)I have a really old muffler that needs replacing. warms up, can breate... 4.)Air in. (I know ill start some fights here, but it has the oil mess, I swear it can not get enough air) Any ideas? It’s a daily driver, and it is annoying as heck. |
broomhandle |
i thought it was vac lines as well, but i replaced them all.
i will try what you guys say. what = AAR (Auxiliary Air Regulator) MPS (manifold PS) TPS (Temperature Sensor) PS im assuming is Pres sens... is this correct? |
DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,769 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
i thought it was vac lines as well, but i replaced them all. i will try what you guys say. what = AAR (Auxiliary Air Regulator) -- yes MPS (manifold PS) -- yes TPS (Temperature Sensor) no- this is the throttle position sensor - PS im assuming is Pres sens... is this correct? the TPS is on the front of the throttle body- a black plastic cover , opposite side of the throttle return spring. this has circuit board that gets worn or dirty, sometimes just needs to be cleaned off so the contacts will signal the throttle position properly, allowing for proper idle. - if you car bucks sometimes when under a steady rpm , say 3000 steady and you feel that it is most likely a tps issue. Attached image(s) ![]() |
Lo-Fi Version | Time is now: 25th June 2024 - 12:20 AM |
