Engine idle raise drop, cold… DJet help., up/down/up/down.... |
broomhandle |
Oct 27 2011, 11:03 AM
Member Group: Members Posts: 290 Joined: 26-June 09 From: Half Moon Bay, CA Member No.: 10,512 Region Association: Northern California |
My 1.7 when started, the idle will go up and down, even for about an hour of driving. After an hour (here or there) the idle stays up and drops for awhile. And then it is fine… but can drop back down sometimes. On hotter days, it seems like it is faster to a normal running idle. I had 4 ideas: 1.)Cold temp sensors, I know there are 2 but I am unsure about it. Or how to test. 2.)Fuel/vacuum. This was my 1st thought, so I have new lines around the motor and the top of the tank. And the injectors have been re-built. but still could be djet. 3.)I have a really old muffler that needs replacing. warms up, can breate... 4.)Air in. (I know ill start some fights here, but it has the oil mess, I swear it can not get enough air) Any ideas? It’s a daily driver, and it is annoying as heck. |
Spoke |
Oct 28 2011, 02:27 PM
Jerry Group: Members Posts: 7,052 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
With the engine idling, spray carb cleaner on all hoses, interfaces. When you hit the leak, the engine note will change.
Lo-Fi Version | Time is now: 26th September 2024 - 11:45 AM |
