> Floor pan rust inside! Found some in my LE, Pull your seat out & check yours
JRust
post Oct 25 2011, 10:09 PM
Okay I was pulling my interior to install my new dash & backpad. Down by my seat hinge I see some rust around the hinge mount. It was between the sound deadening factory stuff & the mount. It started around the mount & worked it's way across. I had one tiny hole through & some spots if it hadn't been seen would have gone through. Another gift from my car sitting outside at the wrench who screwed me a while back. He just keeps giving & giving (IMG:style_emoticons/default/headbang.gif) .
So I scraped all the sound deadening off on the rear drivers side pan. I treated it with some rust stuff I have. Tonight I scraped off most the front sound deadening. It was great with the exception of a little more around the pedal. I can tell it is just surface rust but it is coming out. I plan to use bedliner to redo the floor. Then I am going to paint it L80E to match my car.
Here are a few pics to check out of the area mostly scraped up. I haven't started on the passenger side but if it has the same issue I will get some before pics.
What have you used to replace the sound deadening (IMG:style_emoticons/default/confused24.gif)
dlestep
post Oct 28 2011, 09:13 PM
I am smilin'...
There are natural harmonics of the 914
and then there is structural borne sound propagating through sections of the
body. The floor pan sheet steel is a natural speaker over a frame that
happens to be upside-down.
To disrupt structure borne sound, a simple pad of non-conducting material
is all that is required.
I used seam sealer around where the longs meet the floor and made my
own seal between the master cylinder and the forward wall allowing only the
shaft to protude, to eliminate as much water intrusion as I can.
On the floor, I am using 1/4 inch Solid Rubber sheeting so I can keep the
floor clean and eliminate scratching of the surfaces. It also eliminates the
transmission of sound from the floor pan surface. It is one piece and is cut
to the shape of the floor, from long to center hump, and from cross bar to
forward wall.
The rubber sheeting is dense and has weight and doesn't require adhesives.
It also doesn't lift or move in use, but can easily be removed when cleaning.
I live in Florida, I hate sand and leaves, and I am constantly cleaning the floors.
JRust   Floor pan rust inside! Found some in my LE   Oct 25 2011, 10:09 PM
rjames   you can use the dynomat stuff or similar product o...   Oct 25 2011, 11:04 PM
mark21742   I've used and plan to use truck bed liner........   Oct 26 2011, 04:58 AM
rdauenhauer   I used the reproduction tar mats that George offer...   Oct 26 2011, 08:22 AM
JRust   Yeah I have a little bit of surface rust by my ped...   Oct 26 2011, 11:09 AM
SirAndy   What have you used to replace the sound deadening ...   Oct 26 2011, 11:18 AM
ConeDodger   What have you used to replace the sound deadening...   Oct 26 2011, 11:24 AM
JRust   Who has the replacement tar mats? I didn't see...   Oct 26 2011, 01:43 PM
JRust   Please tell me doubleA isn't the only place to...   Oct 27 2011, 10:38 AM
r_towle   Are you seeking a replacement that appears to be s...   Oct 27 2011, 10:49 AM
SirAndy   Lizard Skin Any bed-liner, including "Lizar...   Oct 27 2011, 11:18 AM
r_towle   Lizard Skin Any bed-liner, including "Liza...   Oct 27 2011, 11:22 AM
SirAndy   Do you seriously get in and remove your floor mat ...   Oct 27 2011, 11:23 AM
jsayre914   I would suggest that you strip and epoxy paint th...   Oct 27 2011, 05:28 PM
JRust   I'm going to test some bedliner product tonigh...   Oct 27 2011, 01:00 PM
SirAndy   Getting something shipped in a timely manner can b...   Oct 27 2011, 01:49 PM
JRust   By far the quickest way would be to just clean th...   Oct 27 2011, 03:58 PM
Rand   Once my back recovers from all this scraping. I a...   Oct 27 2011, 04:10 PM
70_914   JC Whitney sells sound deadener. Some of their st...   Oct 27 2011, 01:55 PM
bandjoey   Ditto. HF milti tool cuts the old tar off in 30 m...   Oct 27 2011, 04:19 PM
ewdysar   Hey I just looked under my driver seat... is this...   Oct 27 2011, 05:31 PM
SirAndy   Hey I just looked under my driver seat... is this...   Oct 27 2011, 05:59 PM
ewdysar   Hey I just looked under my driver seat... is thi...   Oct 27 2011, 06:23 PM
dlestep   There are natural harmonics of the 914 and then th...   Oct 28 2011, 09:13 PM
rdauenhauer   EDIT I am using 1/4 inch Solid Rubber sheeting I...   Oct 28 2011, 11:19 PM
dlestep   [quote name='dlestep' post='1563224' date='Oct 28...   Oct 29 2011, 02:28 PM
JRust   Okay I am almost there cleaning up the floor. I al...   Oct 29 2011, 10:01 PM
JRust   Spent a little more time last night. Got the passe...   Nov 2 2011, 12:58 PM
sixaddict   The only way to varify good metal is strip is off ...   Nov 2 2011, 07:35 PM
- Lo-Fi Version Time is now: 6th January 2025 - 04:47 PM
