Coolant hose sizing, 914s are air-cooled? But SHO-914s are H2O! |
3d914 |
Oct 30 2011, 08:04 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
I'm gathering data for my 914-SHO conversion about getting the coolant from the front to the mid-engine position. The fitting sizes on the engine appear to 1-1/4" for inlet and 1-1/2" for outlet.
I don't have the fitting sizes on the radiator - you think they'd match, but that's not a given. Still doing more research there. I'd like to get the supply hose down to 1" and the return to 1-1/4" to make routing along the body easier. Any thoughts, experiences from the V8/V6 folks? TIA, |
Mike Bellis |
Oct 30 2011, 09:18 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
On my V8 I used Drake 1" hose. Temps always around 165. On my rotary I switched to 1-1/8" hose because the engine runs hotter by design. Temps constant 180.
Either way will work for you. The Renegade Hybrid adapters are very restrictive they go from 1.5" to 7/8", but they seem to work fine. I eliminated all adapters for my rotary. I built just one 1-3/4" to 1-1/8" for the lower rad outlet. |
Lo-Fi Version | Time is now: 23rd June 2024 - 01:27 PM |
