Indicator light in dash keeps flashing?, is it a warning light |
porschefile2010 |
Nov 1 2011, 01:30 AM
Member Group: Members Posts: 228 Joined: 26-May 11 From: Whangaparaoa, New Zealand Member No.: 13,118 Region Association: Australia and New Zealand |
The indicator light in my dash starts flashing continually at a faster than normal speed when I turn the key on and still goes when the engine is running. All the turn lights and emergency flasher work as they should. If I use the turn indicator the light indicates as it should but at normal speed.
I don'thave an owners manual so does anyone know if this is a warning of some sort? |
pcar916 |
Nov 1 2011, 05:11 AM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
(IMG:style_emoticons/default/agree.gif) While you're in there and unless you've done it recently, make sure all of your bulb contacts and connectors are corrosion-free.
Good luck |
Lo-Fi Version | Time is now: 24th September 2024 - 01:00 PM |
