scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
(IMG:style_emoticons/default/WTF.gif) HOW ?? (IMG:style_emoticons/default/confused24.gif)
My first and possibly last time doing the rear bushings (IMG:style_emoticons/default/dry.gif) I've spent almost 30 minutes trying to get one of these damned things on. I popped all 4 onto the ball ends of the bar and the shock mounts, but how in the hell do you get the drop links on ? You can't put the links on first because the bushings collapse under the force without the ball insde for support. I've tried the bench vise, the press, smacking it with a hammer. All it will do is cock to one side and start compressing (IMG:style_emoticons/default/headbang.gif) I've slatherd the outside with pet. jelly, should I get that off and do it dry ? (IMG:style_emoticons/default/huh.gif) Attached image(s) ![]() |
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,185 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
(IMG:style_emoticons/default/confused24.gif) Ive done it the opposite way you describe, install into the links first, use a C-clamp to compress/install onto the bar, then position and using a dead blow hammer smack the back side of the link/bushing onto the shock pin.
One hint is use the hot water trick just like the firewall bushing (IMG:style_emoticons/default/smile.gif) |
Millerwelds |
Pleepleus ![]() ![]() ![]() Group: Members Posts: 715 Joined: 24-June 08 From: Grass Valley, CA Member No.: 9,206 Region Association: Northern California ![]() |
(IMG:style_emoticons/default/confused24.gif) Ive done it the opposite way you describe, install into the links first, use a C-clamp to compress/install onto the bar, then position and using a dead blow hammer smack the back side of the link/bushing onto the shock pin. One hint is use the hot water trick just like the firewall bushing (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:34 PM |
