76/2.0/4 hard start |
street legal go-kart |
Apr 15 2003, 09:16 PM
Miss Mari's slave Group: Members Posts: 437 Joined: 28-March 03 From: sierra nevada ,cali . Member No.: 490 |
gdday
ONE car has always started with no throttle or any extended cranking . even at 20 degrees f . ALWAYS started and idled at 900 rpm at once . sat morn. had to blip th throttle to keep the car running and restart the car numerous times . if i held the engine at at a steady rpm the engine would drop and die within 2 secs . checked for any loose conectors etc. mon same thing after i let the car sit all day , not as dramatic the but the same thing . after about 2 mins , the car behaves as always , (IMG:style_emoticons/default/confused24.gif) same level of perfomance . no fuel line leaks , new points in the fuel pump , fuel filter 500 miles ago etc . any help thx in advance jt |
Bleyseng |
Apr 15 2003, 09:20 PM
Aircooled Baby! Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Maybe it's time to lube the AAR valve so your idle goes up to 1500 rpms when cold. Spray some knock loose or PB Blaster (not WD40) into the valve after taking a hose off. That will lube it so it works right.
Geoff |
Lo-Fi Version | Time is now: 14th January 2025 - 07:07 AM |
