Permission requested to remove jackstands, Drove it for the first time in 4 years! |
bigkensteele |
Nov 14 2011, 02:12 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
This is how she sat, waiting for an engine re-seal...
Finally on her own feet! Took a lot of cranking to get it started. I didn't think that I was getting fuel pressure, so I pulled out the pump to check the wires. They looked fine, so I left it out to see if I could hear it when I turned the key, and then it started firing. I think that one of the hoses may have been kinked, and probably got freed when I pulled the pump out. Curiously, I never heard the pump at all, even though I have heard to listen for it. After it actually started, it ran horribly for a while and then started to smooth out. I took it for a short spin, and was loving life, even though it is still running like crap. (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving.gif) |
bigkensteele |
Nov 14 2011, 02:38 PM
I actually replaced all of those vacuum hoses (except the 22mm that is not included in the AA kit).
Removed the points and condensor and replaced with a Pertronix, however, I did not replace the FI points. Didn't even really think about it to tell you the truth. Might look at that... |
type47 |
Nov 14 2011, 06:19 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
...however, I did not replace the FI points. ... I don't think you have FI points (IMG:style_emoticons/default/idea.gif) |
nowlings |
Nov 14 2011, 06:28 PM
Newbie Group: Members Posts: 28 Joined: 21-March 07 From: sacramento Member No.: 7,615 |
...however, I did not replace the FI points. ... I don't think you have FI points (IMG:style_emoticons/default/idea.gif) Picture looks like a 1.8 l. so no injection points on AFC ljet. Good luck... I would double check all of your hose connections and boot installation for vacuum leaks. any unmetered air=crappy running and a potentially warped flapper door in the afc unit. |
Black22 |
Nov 14 2011, 07:24 PM
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
...however, I did not replace the FI points. ... I don't think you have FI points (IMG:style_emoticons/default/idea.gif) Picture looks like a 1.8 l. so no injection points on AFC ljet. Good luck... I would double check all of your hose connections and boot installation for vacuum leaks. any unmetered air=crappy running and a potentially warped flapper door in the afc unit. That's what I was going to say...looks like a 1.8L....if it is, no trigger points in that dizzy. Oh yeah, if that's what you call a "reseal" of the engine, you can reseal mine whenever you have a moment! |
Lo-Fi Version | Time is now: 21st September 2024 - 10:02 PM |
