bigkensteele |
Major Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States ![]() ![]() |
This is how she sat, waiting for an engine re-seal...
![]() Finally on her own feet! ![]() Took a lot of cranking to get it started. I didn't think that I was getting fuel pressure, so I pulled out the pump to check the wires. They looked fine, so I left it out to see if I could hear it when I turned the key, and then it started firing. I think that one of the hoses may have been kinked, and probably got freed when I pulled the pump out. Curiously, I never heard the pump at all, even though I have heard to listen for it. After it actually started, it ran horribly for a while and then started to smooth out. I took it for a short spin, and was loving life, even though it is still running like crap. (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving.gif) |
bigkensteele |
I actually replaced all of those vacuum hoses (except the 22mm that is not included in the AA kit).
Removed the points and condensor and replaced with a Pertronix, however, I did not replace the FI points. Didn't even really think about it to tell you the truth. Might look at that... |
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
...however, I did not replace the FI points. ... I don't think you have FI points (IMG:style_emoticons/default/idea.gif) |
nowlings |
Newbie ![]() Group: Members Posts: 28 Joined: 21-March 07 From: sacramento Member No.: 7,615 ![]() |
...however, I did not replace the FI points. ... I don't think you have FI points (IMG:style_emoticons/default/idea.gif) Picture looks like a 1.8 l. so no injection points on AFC ljet. Good luck... I would double check all of your hose connections and boot installation for vacuum leaks. any unmetered air=crappy running and a potentially warped flapper door in the afc unit. |
bigkensteele |
...however, I did not replace the FI points. ... I don't think you have FI points (IMG:style_emoticons/default/idea.gif) Picture looks like a 1.8 l. so no injection points on AFC ljet. Good luck... I would double check all of your hose connections and boot installation for vacuum leaks. any unmetered air=crappy running and a potentially warped flapper door in the afc unit. I will double check them, but they are all new except for the 22mm that goes from the oil filler neck to the boot, and the other 22mm from the boot to the decel valve. Those are not included in the AA kit, for some reason. How tall do you have to be to time a 914? I am only about 5' 8", and I think that I am going to have to lay across the trunk lid to point the gun and see down the hole at the same time. Is there a better way? |
Lo-Fi Version | Time is now: 20th June 2024 - 08:53 AM |
