Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
It gets cold here in Northern California often in the moorning. So I decided to build a liquid heater. First, I spent some time measuring the inside of the fresh air box. I figured I could fit a core 11x6 maximum. my son and I spent several hours at the local Pick and Pull junk yard. I settled on a Transmission cooler from a late model Ford Truck. Cooler measures 10x6.
![]() I quick placement and I realize I need to cut! The water dam for the fan must be cut down. Make sure not to cut all of it so that it will still keep some water off the motor. ![]() The finish cut to the dam. Ready for the lid? Not yet. ![]() |
Brett W |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,858 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None ![]() ![]() |
Why not find a way to retrofit the heater box and accumulator from a modern car under the dash. This would give you heat, defrost, AC, and the multi speed blower motor. I was looking over my new car and it looks like the dash area is similar in size to the dash area on my CRX.
andys |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None ![]() ![]() |
Why not find a way to retrofit the heater box and accumulator from a modern car under the dash. This would give you heat, defrost, AC, and the multi speed blower motor. I was looking over my new car and it looks like the dash area is similar in size to the dash area on my CRX. It would be great to find something to rerofit from a small production car. I bought an under dash AC evaporator with heat and defrost from HRA for my V8 conversion car, so all those things you mention are there. Plumbing in the ducting will be trick however. Andys |
Lo-Fi Version | Time is now: 20th April 2025 - 03:42 AM |
