SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,171 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
So, after having had the pleasure to drive this beautiful, unmolested, all original, 37k miles 914-6 today, i can't help but wonder if we should attempt to list all the differences between an early /6 and early /4 in terms of originality.
I believe it would be of tremendous help to have a list of things "to look for" when doing a PPI on such a time-capsule. What do ya'all think? (IMG:style_emoticons/default/idea.gif) Andy ![]() |
SirAndy |
i'll start ... (IMG:style_emoticons/default/biggrin.gif)
- it should have a flat /6, 2.0L motor (doh!) - firewall center engine mount - no /4 mounts - factory oil-tank - different relay board - "hook" for the oil-line on drivers side rear long - 911 style ignition switch and column for '70/'71 models - *no* hole in the front trunk for the /4 air hose to the spare tire - black "tar" around the front upper shock towers - different windshield washer bottle - electric washer pump - real 5-lug axles - "914-6" badge - handthrottle in front of the shifter - different throttle cable routing, using a tranny mounted pivot - different paint code on the karman badge - different VIN, starting with "914" (doh! again) - no rain-tray under engine lid. - Dash top has no center vent - - what else? (IMG:style_emoticons/default/idea.gif) Andy |
JMKnight |
Aces & Eights ![]() ![]() Group: Members Posts: 135 Joined: 30-December 09 From: Northern Indiana Member No.: 11,188 Region Association: Upper MidWest ![]() |
(IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/smile.gif)
i'll start ... (IMG:style_emoticons/default/biggrin.gif) - it should have a flat /6, 2.0L motor (doh!) - firewall center engine mount - no /4 mounts - factory oil-tank - different relay board - "hook" for the oil-line on drivers side rear long - 911 style ignition switch and column for '70/'71 models - *no* hole in the front trunk for the /4 air hose to the spare tire - black "tar" around the front upper shock towers - different windshield washer bottle - electric washer pump - real 5-lug axles - "914-6" badge - handthrottle in front of the shifter - different throttle cable routing, using a tranny mounted pivot - different paint code on the karman badge - different VIN, starting with "914" (doh! again) - no rain-tray under engine lid. - Dash top has no center vent - - what else? (IMG:style_emoticons/default/idea.gif) Andy Rear valance has a hole in which the exaust pipe pokes through, rather than a slot like on the 4's! |
Lo-Fi Version | Time is now: 3rd April 2025 - 01:23 AM |
