Speedster Mike |
Speedster Mike ![]() Group: Members Posts: 39 Joined: 1-March 09 From: Louisville , Ky. Member No.: 10,113 Region Association: Upper MidWest ![]() |
Hey Guys I have FOR SALE a Brand new AA Big Bore 96m High Performance Flat top, Piston and cylinder Kit to fit the 1.7 or 1.8 Motor. Also comes with Piston pins ,clips and rings. I decided to build a bigger motor with a different crank so these are not needed. This is a great way to increase compression and performance! Or just freshen up your motor and give it more kick...! Still in the original box. I'll take $249.00 plus shipping to where ever you live. PM me or call or text 502-797-7636
Thanks, Mike Attached thumbnail(s) ![]() ![]() ![]() |
7275914911 |
Hummmm!!! ![]() ![]() ![]() Group: Members Posts: 756 Joined: 7-May 08 From: Mid-South Member No.: 9,028 Region Association: South East States ![]() ![]() |
Since it is 1.7/1.8 IIRC it is a 66 stroke.
Speedster Mike |
Since it is 1.7/1.8 IIRC it is a 66 stroke. That's correct! .....These will fit the 1.7 or 1.8 engine Type IV engine with the stock 66m crank and stock rods. These are easy drop in (Slipper skirt) with no machine work to be done for the 1.7 and 1.8 block. No machine work for the 1.8 or 2.0 heads. However the 1.7 heads will have to be milled (opened up) to fit the bigger cylinders if they have not already been opened up previously. Which is not really a big deal...a good machine shop familier with air cooled VW or Porsche engines can do that for you. |
Lo-Fi Version | Time is now: 25th June 2024 - 12:25 AM |
