914itis |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States ![]() |
I have one of the switch or sensor, i am not 100% sure which one it is. ( it is a 2.0 and mounted on the block by the oil cooler. it does not appear to be leaking, but I am not sire if it would leak when broken.
Anyway, as the PO was trying to take it out, It broke. 1- should I extract it and replace? ( I never extracted a bolt before) 2- Should I just leave it alone and seal it? if so what can I use to seal it? |
bigkensteele |
Major Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States ![]() ![]() |
Paul, please post pics of how it broke. Did it break down below the surface where it threads into the case or above? If above, you may be able to use a dremel with a cutoff wheel to grind a slot into it and use a screw driver to extract it.
If it broke below, I would pull the engine and take stock. Do NOT drill it out and run a tap through it. It is a tapered thread, and if you tap it, you will have a hard time sealing a new one. |
Lo-Fi Version | Time is now: 26th June 2024 - 07:17 AM |
