Bosch Distributor VS MSD Ignition, Rotor Bosch Dist. melted when ignited w/ SS Blaster Coil and 6AL |
Ghianto66 |
Nov 27 2011, 11:33 PM
Newbie Group: Members Posts: 5 Joined: 11-November 10 From: Jakarta, Indonesia Member No.: 12,372 Region Association: Indonesia |
Is thre anyone have experiance w/ melted distributor rotor? I have 2.0 motor with MSD 6AL and SS blaster coil, I drive for 100miles but suddenly engine stop, I check for ignition but no FIRE. I check for distributor and it shown melted rotor. I change w/ new rotor but when 100miles it happen again. Distributor its self is original BOSCH. Anyone know which rotor that fit w/ bosch and can hold MSD fire?
Attached thumbnail(s) |
kconway |
Nov 28 2011, 12:12 AM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
There are numerous threads on this issue on Pelican. I think I remember reading you have a high resistance path between the plugs and heads. The return current is having to go through the resistor in the rotor instead of the head. Pull the plugs and clean up the threads at each cylinder...I think?
Lo-Fi Version | Time is now: 26th June 2024 - 05:55 AM |
