tornik550 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None ![]() |
I just got a new KB 96mm piston (I had to replace one damaged piston). The new piston came with two rings that are just a little thicker than the oil rings- they have a dimple on one side. The grove in the piston where the oil rings sit is wider than my older set. The new piston also doesn't have the oil ring locating pin.
What are the rings that came with the piston for? |
bam914 |
Member ![]() ![]() Group: Members Posts: 334 Joined: 23-November 03 From: Atlanta, Ga Member No.: 1,378 Region Association: None ![]() |
You got the newer style KB pistons. That ring is a support for the oil control ring. It goes on the bottom.
Lo-Fi Version | Time is now: 20th June 2024 - 05:52 AM |
